10-19-2003, 12:48 PM | #1 |
Low & Slow
I have no antenna hole... Where should I put one now?
Alright, I have my antenna hole shaved now and I need somewhere to put an antenna that will be out of sight.
I thought about mounting it under the cowl but, i'm open for sugestions. Thanks
70' C-10 LWB Fleetside 4.5/6 drop |
10-19-2003, 01:19 PM | #2 |
built not bought
instead of using an antenna, you can just get a length of antenna co-ax 4-6 ft long and about a foot from the end you plug in to the radio, strip the outer covering and the braided shield. this will leave just the center conductor and the center conducter covering. then run this length of wire under the dash, trying to keep it as high as possible. this basically makes the antenna coax an antenna. i install stereos for a living and this method works pretty well.
10-19-2003, 01:27 PM | #3 |
thats a good idea
70 longbed 496/th400/Ford 9" |
10-19-2003, 01:52 PM | #4 |
Inline 69
go buy a 8" "rubber" antenae from kragens,auto zone,they work fine, just tie rap it under your dash,,,,,,,,,,,,,,,,previous post,, http://67-72chevytrucks.com/vboard/s...rubber+antenae
10-19-2003, 02:31 PM | #5 |
Low & Slow
Thanks for the replies! tswore, I actually have my old antenna that some little punk broke the mast off of so, I'll just cut into the wire like you are saying. I didn't even think about that! thanks! I love the "free" things lol
10-19-2003, 03:21 PM | #6 |
its all about the +6 inches
And to add to the under dash wire or rubber antenna, if the stations that you like don't come in too well, go to wall mart and get the FM signal booster, and wire it in. It is unseen, and works quite well.
10-19-2003, 04:51 PM | #7 |
Low & Slow
Well... just got done test fitting my new console I built last night and put the antenna wire back in after stripping the outside of it off. Thanks again guys for the replies.
10-20-2003, 04:10 PM | #8 |
This is A question PLEASE help. How about pulling the body panel foward of the windshield, and mounting an antenna inside that area where the windshield wiper linkage is at. using clamps and mounting it solid, fully extended sideways across there. I hope I explained this good enough. any thoughts????
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
10-20-2003, 04:44 PM | #9 |
Low & Slow
70short, that was what I was thinking about doing at first but I tried what tswore said above and it is working great for me, although I don't really listen to the radio.
10-20-2003, 04:58 PM | #10 |
replace Windshield with built in Antenna, my 81 has it like that
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ "Why couldn't you have just put the bunny back in the box?" ~ |
10-20-2003, 11:09 PM | #11 | |
You can place the ant under the cowl panel no problem. If anyone does this, paint it flat black so it won't be seen as easily. |
