1965 LS Swap
Finally completed the LS Swap on my 65 C10, but having problems with the way we spliced the new fuel lines off the donor truck to my 65 lines. Has anyone found a kit that works good for fuel rail back to tank? It is fuel injected not carb...
Thanks |
Re: 1965 LS Swap
I haven't come across any kit, as there are a bunch of ways to do it. You running hard lines, AN lines, combination of both? What is your fuelpump/filter setup?
Re: 1965 LS Swap
I couldn't get the tank behind the seat to work because it didn't have a vent or something. I hear you can use a inline fuel pump and Corvette fuel filter But it did not work for me (I tried twice). I had to install a k5 blazer 30 gal tank under the bed and it cost right around 450- 500 for everything and has the return line. I have a 5.3 ls with 4l60e and a dually 14 bolt rearend.
Re: 1965 LS Swap
I have a 1992 Chevy blazer tank and fuel pump, the guy that ran mine pieced it together and is leaking in several spots. Plus the stock fuel pump will not be big enough to handle spray. Just trying to clean up a mess basically.
![]() ![]() Join Date: May 2015
Re: 1965 LS Swap
That's going to be a high pressure line..don't skimp on fuel lines..I used s/s braid from my pump to the fuel rail..some have used the factory style lines..whatever you choose to run the less connections you have the better..I used a walbro 255 and a vette filter/reg on mine..
![]() Join Date: Aug 2004
Re: 1965 LS Swap
This is what I got, mind you I did mine in 2008 ish and there wasn't a large option for vendors. I also didn't need the regulator either. Pump is quiet and still running strong
http://www.turnkeyenginesupply.com/f...e-1-to-450-hp/
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#7 | |
Re: 1965 LS Swap
meowMEOWmeowMEOW
Re: 1965 LS Swap
IMO just hardline everything that you can. Get it down to just a few connections (pump, filter® or vette reg, rail) and then make a couple of braided lines with high quality AN fittings. Simple, serviceable, and you save the money on hardline you can use for braided lines.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
