04-13-2017, 08:15 AM | #1 |
order to assemble front sheet metal?
What's the best way to assemble the front end sheet metal. Everything is off. Start with radiator support, then ???, then ???, then ???
04-13-2017, 11:17 AM | #2 |
Re: order to assemble front sheet metal?
Rad support first.
Then each fender bolted on loosely Get the Grill and associated pieces in there. Inner fenders wells. Hood Cowl Then go around and align and snug everything.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
04-13-2017, 11:48 AM | #3 |
Make sure the doors are properly aligned first but yup what he said.
Saskatoon, Saskatchewan Canada |
04-13-2017, 11:53 AM | #4 |
04-13-2017, 12:19 PM | #5 |
To put on rockers, the fenders need to be off. I hope I didn't just spit in your oatmeal.[ruin your day] I would hate for you to spend a lot of time putting on the front then have to take it right back off.
By the way to get the front aligned better [or at all] you probably need fresh cab and front mounts. |
04-13-2017, 01:16 PM | #6 | |
04-13-2017, 01:57 PM | #7 |
Once again make sure you have your doors where you like them before making the the rockers permanent. Too many have found out later that their doors won't close. Everything is centered around door fit. I screw and tack everything and assemble of the way to the front to check fit before I weld anything. It's a lot of work but it's the only way to get nice gaps. That includes the hood and cowl panel too.
04-13-2017, 02:11 PM | #8 |
Go Pack Go!
I hope you welded braces into the door opening from front to rear before all that floor and rocker work. The cabs have a tendacy to warp, spread open when that much structure is removed.
04-13-2017, 01:24 PM | #9 | ||
"I ain't nobody, dork."
Just start bolting stuff together. You'll immediately figure out what need to go before the other.
Gary
04-13-2017, 02:38 PM | #10 |
I was told the front cab bolts have to be out. Is that you guys' experience also?
04-13-2017, 03:52 PM | #11 |
04-13-2017, 03:51 PM | #12 | ||
I've pulled off a lot of these front clips. Either piece by piece or one whole unit. Never had to remove front cab bolts.
Gary
04-13-2017, 09:48 PM | #13 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
You do not have to pull the cab support bolts! But you do want to have them loose, front and rear especially if you've replaced the floor pan(s). Bolts stuck but loose, same way with the radiator support bolts, leave them loose until you've fitted the fenders, inner fenders and doors. Keep in mind the further back your cab is located the tighter the gap to the bed, thats a good thing. You also leave plenty of relief for the fenders and doors by leaving the cab support bolts loose. Hopefully you've replaced or still have solid cab supports and support bushings so bed alingment will be good when it goes on. Before you tighten the fender bolts to the radiator support, make sure your width is good for the hood, a little at a time front to rear. Tight hinges with good strong springs are key to fitting the hood correctly. Dont be afraid to use body washers at the rear of the fenders, door hinges and strikers, and the cowl to get a good final fit up and keep track of where washers are used if you haven't done so already...~Ghostrider~
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
04-24-2017, 08:37 PM | #14 |
I have a bare frame not sure where to start with mine suspension so I ca roll it around or cab and motor and wiring?
04-24-2017, 09:59 PM | #15 |
I am a Referee of life.
Suspension first so you can get everything, Then motor, cab and the rest.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
