Old 10-19-2003, 11:03 PM   #1
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Question my truck wont start? Fuelpump dead?
Hey all. My truck once in a while wont start. I drove it home 600 miles with no problem & it stalled after hitting a bump in front of my house & I went out about an hour later & it started. It ran this afternoon but when I tried to start it to put it back into the garage-no go. It started for about two seconds & died & wont start. It sat for 14 years prior to my getting it & I'm THINKING that an intermittantly failing fuel pump would cause such a situation. Comments? Has anyone had a fuelpump that works & then stops & then goes again? What do you think?
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 10-19-2003, 11:30 PM   #2
70c10
67-72 Addict!
70c10's Avatar
When my last pump went up it started to leak.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-19-2003, 11:37 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
My first guess would be something in the ignition system. I would first check for spark.
To check the fuel system, disconnect the fuel line going to the carb and stick it in a clear container, such as a pop bottle. Have someone crank the engine and see if you're getting fuel. If no fuel is pumped, next check is to see if fuel flows out the tank. Also if you have a fuel filter in line, check it for flow.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 10-19-2003, 11:57 PM   #4
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Its not the fuel pump. Gotta be a loose connection in the ignition system.
Unless you have an electric fuel pump and it has a loose connection.
Cat Fuzz is offline   Reply With Quote
Old 10-20-2003, 02:36 AM   #5
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
usually when a fuel pump goes (mechanical), the engine will run like crap if at all. However, my truck acted about like you describe for awhile, turned out to be the fuel filter. Sitting that long, you might have jarred a little rust out of the line or something when you hit the bump and it was enough to clog the filter, then when it cools, the crap settles down, then gets picked back up agian.....wierd things happen with old trucks.....or anything with wheels......or mechanical for that matter.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 10-21-2003, 10:00 PM   #6
passthebuck
update
So I was thinking about how the truck started & ran for a few seconds & died. I still figured it was fuel & an ez way to check that was to pour a spraycan cap full of gas down the carb & start it up. It ran & died in about 4 seconds. A-HA! Its either fuel pump OR a fuel filter. I unhooked the hardline at the carb & cranked it & fuel went EVERYWHERE. The previous owner cut the hardline & put an aftermarket steel filter. I unhooked it & outcame stuff that looked like fine coffee grounds! A new filter & she ran a-ok. I'm thinking that I should keep an extra one in the glovebax should I ever need to do it again & I think I will due to the krap in the filter. I'm thinking that after I get it road-legal I've gotta get that tank steam cleaned. Thanks to all you cats who replied to my post!
passthebuck
#5642
Old 10-21-2003, 10:18 PM   #7
Denny
Denny's Avatar
That rust in the gas tank can get real aggrevating. I put a new gas tank in my truck a couple years ago and just put all stainless gas lines on her this year. I was real surprised to see how much rust coating was in the gas line that runs to the pump from the tank. I guess 34 years is a long time on fuel lines and gas tanks.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
