Old 04-26-2017, 07:29 PM   #1
creole
Interchange tailgate
I inherited a 1977 single cab c-30 camper special dually that has no tailgate. What other years of tailgate will fit this 1977 with little to no modification?
creole is offline   Reply With Quote
Old 04-26-2017, 08:10 PM   #2
bbbc10
Diggin The SquareLife
Re: Interchange tailgate
ummmmmmmm anything from 73-87 simple to figure out
bbbc10 is offline   Reply With Quote
Old 04-26-2017, 08:25 PM   #3
duallydude63
actually if its a crewcab u can go up to 91 they have the same tailgate
duallydude63 is offline   Reply With Quote
Old 04-26-2017, 09:40 PM   #4
Dead Parrot
Just be sure to get ALL the mounting hardware with the tailgate. While the bolt holes on the bed sides stayed the same, there are differences in the tailgate hardware between the model years that can make a mixed year setup not work.
Dead Parrot is offline   Reply With Quote
Old 04-26-2017, 10:00 PM   #5
100%Chevy
That's right.A 73/80 tailgate will work the best,but the newer ones will work with some minor changes to the hardware and bump stops.
I have an 82 on my 77.Fits fine after some adjusting.
Mike.
100%Chevy is offline   Reply With Quote
Old 04-27-2017, 01:41 PM   #6
RedBed
RedBed's Avatar
Slightly off-topic, but if you want a cheap and simple way to deter tailgate theft, this may help. I used a metal panel clip and a screw to make it so you can't just slip the tailgate off.
RedBed is offline   Reply With Quote
Old 04-28-2017, 01:32 AM   #7
El Dorado Jim
good idea! thanks
El Dorado Jim is offline   Reply With Quote
Old 04-28-2017, 08:30 PM   #8
gmachinz
Originally Posted by El Dorado Jim View Post
good idea! thanks
What if the thief has a Phillips screwdriver? lol j/k maybe use a tamper proof torx headed machine screw instead.
gmachinz is offline   Reply With Quote
Old 04-27-2017, 02:08 PM   #9
creole
Old 04-28-2017, 01:33 AM   #10
El Dorado Jim
73-74 tailgates are different and I'm pretty sure will not work on your truck
Old 04-28-2017, 12:31 PM   #11
WyattTX
All tailgates from 73-87 will work, but there are different syles. 73-74, has name stamped in center, 75-80 is similar but a little different, 81-87, or 81-91 if you count crew cabs, are more squared off in the center stamping, and have the name in the bottom right.
WyattTX is offline   Reply With Quote
Old 05-08-2017, 09:11 AM   #12
Warrens69GMC
Warrens69GMC's Avatar
It will work. I have a 1973 on my 1978 and I had to grind off the "nose" off the top of the tailgate
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 04-28-2017, 01:17 PM   #13
cajundragger
Do you have pictures of the 73-74?
I thought it was just two styles? One with Chevrolet centered and one with it off to the right. And the hardware switched from stud to bolt or something.
cajundragger is offline   Reply With Quote
Old 04-28-2017, 03:13 PM   #14
WyattTX
You may be right, but I know for a fact 81-87 is much different.
Old 04-28-2017, 03:22 PM   #15
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
73-74 use the same hardware as 75-76 but are strictly bolt on.
75-76 was the first of the quick release tailgates where you didn't have to unbolt the trunions to remove the tailgate.
76 2nd design to 80 were the same visually but the latch and link assemblies changed.
1981 introduced the trunion/hinge that bolted to the tailgate, and the lower skin of the tailgate was different than the older gates.
Within all of these there were different emblems as well. You can put a 77-91 tailgate (with appropriate hardware) and any early truck, but the 77 and newer trucks do not have the hole in the bedside for the catch built into the 73-76 bedsides.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 04-28-2017, 08:23 PM   #16
100%Chevy
Here's my NOS,81 up tailgate.
These had a flange on the bottom.Previous years were rolled on the bottom.
Mike.
Old 05-06-2017, 08:32 PM   #17
Mr.Mike
Can anyone tell me how to remove the tailgate from a 1981 Chevy pickup C20 stepside? Is there a trick?
Mr.Mike is offline   Reply With Quote
Old 05-06-2017, 10:14 PM   #18
Sabaka454
Sabaka454's Avatar
Open, unhook latches, lift right corner out.
Sabaka454 is offline   Reply With Quote
Old 05-07-2017, 06:11 AM   #19
Mr.Mike
Does this change still work the same way to take it out?
Old 05-09-2017, 02:35 PM   #20
Keith Seymore
Keith Seymore's Avatar
For a stepside you have to unbolt the trunion from the bedside.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-08-2017, 08:43 AM   #21
gmachinz
Yes they still lift off the same.
Old 05-08-2017, 08:44 AM   #22
gmachinz
My extra NOS 85-87 Chevrolet tailgate is also the same way.
Old 05-09-2017, 11:17 AM   #23
Dead Parrot
Here is a 81+ tailgate working fine on my 75. $30 find at the local Pull-A-Part.
The lower trunion hardware was off the 81 even though is is painted tan.
Old 05-09-2017, 12:49 PM   #24
WyattTX
$30 for a clean tailgate! In my part of the world they would want 10 times or more that amount. Good job shopping!
