Old 05-01-2017, 06:28 PM   #1
Carystone72
1970 K10 pinion yoke.
I went to replace my pinion cause it got messed up and the pinion nut came off super easy, and before I started there was a little back and forth just on the yoke not the shaft from the diff. A toddler could have broken this nut off. Any advice on when I go to replace and install the yoke? Should I just go to the torque spec? Anything helps.
Carystone72 is offline   Reply With Quote
Old 05-01-2017, 07:00 PM   #2
harpo231
harpo231's Avatar
Re: 1970 K10 pinion yoke.
TYpically you will need to replace the crush ring first, crush it then torque to 150
harpo231 is offline   Reply With Quote
Old 05-01-2017, 09:57 PM   #3
Mike C
Mike C's Avatar
Put it back together with a new seal. Use a new nut. Crank it down tight with a 1/2" ratchet. No way you should be able to crush the sleeve anymore than it was. After that, should be good to go.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-02-2017, 02:00 AM   #4
El Dorado Jim
x2 use a new nut...
El Dorado Jim is offline   Reply With Quote
Old 05-02-2017, 10:27 AM   #5
harpo231
harpo231's Avatar
I only say new crush ring cuz overcrushed if nut comes off as you describe
