Old 05-02-2017, 06:13 PM   #1
Harrison.
Core support/radiator support holes
Can someone help me identify a few of these holes? I'm filling un-needed holes and there area a handful I can't figure out. First off, there's a big hole right above the hole for the parking lamp on the passenger side :
Then on each side near the top there is this little 1/2" or so hole:
And finally there are two small 3/8" or so holes right at each corner of the opening for the radiator:
Do I need all of these? Thanks!
http://harrisonspeed.com
Instagram: harrisonspeed
Harrison. is offline   Reply With Quote
Old 05-02-2017, 07:36 PM   #2
Nomadicflyer
Nomadicflyer's Avatar
Re: Core support/radiator support holes
Here's what they are on my truck. Your results may vary...
1972 C20
The hole with the beveled recess is for the parking/turn signal lights. View of both sides.
Upper corner of the radiator cut out is where I mount my transmission oil cooler. I'm not sure if that's for the AC condenser mount, or a shroud. Someone else will have to answer that.
Good luck!
1972 C20 Fleetside "Miss Olive"
http://67-72chevytrucks.com/vboard/s...d.php?t=721563
Nomadicflyer is offline   Reply With Quote
Old 05-03-2017, 08:58 AM   #3
Harrison.
Thanks! Looks like your truck isn't using that big hole near the pass side turn signal pigtail. I'm wondering if you're right, maybe for the AC?
Edit: I looked at the instructions for a vintage AC unit and it does appear that big hole is for the AC lines.
Old 05-03-2017, 09:35 AM   #4
B. W.
B. W.'s Avatar
The large hole is for the A/C lines, the four holes around the radiator opening are for the A/C condenser mounts.
B. W. is offline   Reply With Quote
