Old 05-03-2017, 07:13 PM   #1
Haru
Haru's Avatar
1971 400 C.I oil pan
I've been searching for pan removal/install and plenty of threads and info (thank you).I haven't seen anything with the 400, so does lifting the engine a couple inches / taking the cap off also apply to the BB 400? It's dangling there between a cross member and the dipstick is out :p
I just want to hear this thing run since I was told it runs. (I bought it anyway)
I also bought a one piece gasket rubber gasket, not sure of brand and 6 quarts of 10/40 conventional Castrol and some Permatex copper. Thanks in advance
Haru is offline   Reply With Quote
Old 05-03-2017, 07:30 PM   #2
geezer#99
geezer#99's Avatar
Re: 1971 400 C.I oil pan
YUp!!
BB is the same as a sb.
One more thing is to rotate the motor so the front rod journal is up out of the way.
Old 05-03-2017, 07:35 PM   #3
Haru
Haru's Avatar
Originally Posted by geezer#99 View Post
YUp!!
Was crossing fingers you were going to say it's magical and can been done from the top side from your recliner
Thank you and thanks for the tip /cheers
Old 05-03-2017, 09:06 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
I have a 400 in my '70, and it holds 5 quarts with a filter change. Be sure to just put in 5 and start it to fill the filter, then check. It should be full with 5 quarts.
~Steven
Simi Valley, CA
Old 05-03-2017, 09:12 PM   #5
Haru
Haru's Avatar
Thank you! I may just yank it and start the restore
Old 05-04-2017, 11:11 AM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
The FelPro PermaDry Plus oil pan gasket is the way to go. It is a molded rubber one-piece with steel torque limiters around the bolt holes to prevent over-tightening. I recommend the valve cover gaskets too if running stamped steel valve covers.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-04-2017, 12:11 PM   #7
midniteblues
midniteblues's Avatar
It's a pita too lift the engine too pull the pan and get it all buttoned back up even with a one piece gasket.
If your pickup isn't brazed good it's too easy to shift it upwards.
Plus unless you have a lift all that work laying on your back isn't fun.
I would pull the whole thing so much easier doing it on a stand.
And you can get everything cleaned up nicely.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 05-04-2017, 01:01 PM   #8
Haru
Haru's Avatar
I agree, I kind of want to take it to machine shop and do a top end kit while I'm at it. Any input on that?
Old 05-04-2017, 12:59 PM   #9
Haru
Haru's Avatar
That's the one I picked up, guy at the counter recommended it. Thank you
