Old 05-04-2017, 05:03 AM   #1
az1970k5
az1970k5's Avatar
Transfer case Identification
Seems I have a leak right where the 350 auto and x case connect. All my trans fluid seems to be leaking from there. Hiw can I tell what transfer case I have? As far as I can tell and know, the transfer case in my 70 k-5 is the stock original. There is C-99404 and an A1N just below it.
az1970k5 is offline   Reply With Quote
Old 05-04-2017, 05:31 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Transfer case Identification
New Process 205
There should be a tag on the other side.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-04-2017, 05:42 AM   #3
chestypuller
ya deffinatly a np205
chestypuller is offline   Reply With Quote
Old 05-04-2017, 06:19 AM   #4
az1970k5
az1970k5's Avatar
Thanks for the quick reply chestypuller and Bigdav160. Now to find the correct seals to fix the leak.
Old 05-04-2017, 07:13 AM   #5
jaros44sr
jaros44sr's Avatar
Is it trans fluid leaking
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-04-2017, 07:30 AM   #6
az1970k5
az1970k5's Avatar
Yes trans fluid is leaking right where the transmission and transfer case bolt up
Old 05-04-2017, 08:52 AM   #7
jaros44sr
jaros44sr's Avatar
well then, you better keep an eye, on your trans fluid level, till you get the seals
old saying around here" if its not leaking, your out of fluid"
SAFETY FIRST
AS usual, off topic
Jim
