Walbro fuel pump tip...
I thought I would share my recent experience with mounting a Walbro 255 inline in my 72 K10 6.0 swap...stock in cab tank....I used Moroso rubber mounts to isolate the pump from the frame and it's very quiet. I used the exact same pump on my '62 5.3 swap without the mounts and it was loud... definitely worth the money.
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
![]() ![]() Join Date: May 2015
Re: Walbro fuel pump tip...
Could you post up the part numbers?
meowMEOWmeowMEOW
Mine came with a rubber/foam condom thingy that always kept it fairly quite. I imagine just pump housing straight to metal bracket would be noisy since nothing is eating any of that vibration.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
you have any pictures of your setup?
The isolators are MSD 8800...when I get back I will post some pics
Ok I guess that's why I couldn't findem...msd...not moroso...thanks
Yeah some days I have O-L-D...
meowMEOWmeowMEOW
Here's a couple of pictures.
Starts with stock hard piping>then valve>then ford ranger filter (had it laying around)>then pump>then 100 micron filter. I highly recommend the shutoff valve to service the filters...when I LS swapped my '62, I had lots of dirt get in the filter even though the tank looked clean. I guess the constant return line stirs it up.
Burb99..does your setup use the return rail from engine for your bypass?
Thanks for the pics. good idea on the valve. You recommend a specific part or is that brass fitting anyone can get from Ace HD or lowes?
