Old 05-07-2017, 03:56 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Is this here a spark arrestor?
For parts verification is all......Thank you
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-07-2017, 04:58 PM   #2
terry b
terry b's Avatar
Re: Is this here a spark arrestor?
No crankcase vent.
terry b is offline   Reply With Quote
Old 05-07-2017, 06:20 PM   #3
71CHEVYSHORTBED402
Originally Posted by terry b View Post
No crankcase vent.
Ah, thank you. Do these trucks (71) use spark arrestors? Apparently mine "doesn't".
Tony
Old 05-07-2017, 07:12 PM   #4
terry b
terry b's Avatar
They do not. Hard to get a carb fire with factory air cleaner on tight.
Old 05-07-2017, 07:18 PM   #5
71CHEVYSHORTBED402
Thanks Terry. Nice to know what things are and how they work.
On another note, shouldn't there be two circular gaskets, one on both sides of the spacer? The one that lays on the carb. is fiber. I suspect the one on top of the spacer is supposed to be rubber, which mine was missing. I think they're called air cleaner gaskets.
Tony
Old 05-07-2017, 07:28 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yes. Over the years, mine have been replaced but I'm sure they were both fiber, not rubber. Got replacements at my local NAPA.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-07-2017, 07:32 PM   #7
71CHEVYSHORTBED402
Awesome, thanks for the information.
Tony
Old 05-07-2017, 07:33 PM   #8
terry b
terry b's Avatar
If you drive your truck to real auto parts store. Not a autozone type. Take your adaptor in and they will hook you up. There are different sizes. A old school auto parts dig old stuff.
Old 05-07-2017, 10:01 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yeah, I've never seen other than the paper gaskets in both locations. I've seen a lot of cases where the gaskets were missing, too.
~Steven
Simi Valley, CA
Old 05-07-2017, 10:39 PM   #10
71CHEVYSHORTBED402
Yeah, Napa is generally pretty good for that. Where I live they're the only old school survivor. Gaskets are approx. 5" ID, and 5.1/2" OD. Close enough is online as well. The truck is in no condition to drive anyway. Tearing her down. Very cool, learned how to mount (technically dismount) a carb. today. Simple. Go figure, four 5/16" bolts on a carb plate lifts a big block. Hopefully I'll be there soon, carb. plate or otherwise.
Tony
Old 05-07-2017, 11:24 PM   #11
FirstOwner69
FirstOwner69's Avatar
Actually, that IS what GM referred to as a "flame arrestor" in the 1969 service manuals and as an "arrestor assembly" in the 1972 service manuals.
Here is a link to the patent for the number embossed on mine and a picture showing the internal structure.
Patent 3287094 (note that it's called a flame arrestor here also):
https://www.google.com/patents/US3287094
EDIT: Here's a thread where we discussed it ad nauseam.
http://67-72chevytrucks.com/vboard/s...d.php?t=707424
FirstOwner69 is offline   Reply With Quote
Old 05-08-2017, 12:07 AM   #12
71CHEVYSHORTBED402
Now you did it. I swore I wouldn't open that &**(&^ box again until the rebuild, but for the HUNDREDTH time today, couldn't help myself. Looks like I have a variance of the same thing. The screen on the hose side. No glaring part number, and I refuse to look again.
Tony
Old 05-08-2017, 12:20 AM   #13
FirstOwner69
Sorry... Sorta...
Old 05-08-2017, 12:24 AM   #14
71CHEVYSHORTBED402
Ha! Your arrestor is cleaner than mine.
Tony
Old 05-08-2017, 12:54 AM   #15
RichardJ
Some looked more like this.
In 2013, chewychevy67 posted this.
"I have these 2. The smaller mouth one is from a 68-72 v8 and the larger mouth is from a 67 v8 and 67 and up line 6 with optional closed pos vent"
http://67-72chevytrucks.com/vboard/s...er#post5805555
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 05-08-2017, 08:25 PM   #16
Steeveedee
Who Changed This?
Steeveedee's Avatar
OK, I have the same elbow on my truck, but I don't see a screen inside that elbow. I see that there are some true flame arrestors in this thread, but unless you have a screen in the elbow that goes into the valve cover, it is only an elbow. I've known this truck since 1981, and have never seen that screen in it. I know that flame arrestors are common, my mid-'60s cars came so equipped, in the PCV system.
In looking at post #12, it appears that I maybe should have a screen in there. Any other people have one in there?
~Steven
Simi Valley, CA
Old 05-08-2017, 09:22 PM   #17
dmjlambert
dmjlambert's Avatar
I think it is more than a screen, it has depth to it. I have one of the fat ones RichardJ shows us in the pictures above.
dmjlambert is online now   Reply With Quote
Old 05-10-2017, 12:01 AM   #18
Steeveedee
Who Changed This?
Steeveedee's Avatar
What RichardJ posted appears to be a true "flame arrestor", as in it has a part number (?) Those are made with a short section of sheet metal bent at an angle, inside. If it is just an elbow (not the fat one), I've not seen one with even a screen, as was posted by 71CHEVYSHORTBED402. So, I'm curious what the answer will be. So far I'm just saying what I've seen in the past.
~Steven
Simi Valley, CA
Old 10-07-2020, 12:06 PM   #19
71CHEVYSHORTBED402
The image in the original post was removed. In a nutshell I was looking for the hose and flame arrestor for the crankcase. From the hose is a single unit flame arrestor. Mel is setting me up with one.
Tony
