05-07-2017, 07:14 PM | #1 |
Right outta the paint booth
Fresh paint! Looks amazing can't wait to see it sanded and buffed. Thought at least some of you would like to see..
05-07-2017, 07:25 PM | #2 |
Re: Right outta the paint booth
Wow! Bet that will really POP out in the sun. What color is it?
05-07-2017, 07:29 PM | #3 |
Thanks. Color is Viper Red. Sprayed over a white primer so it really pops. Glasurit base and clear. Very expensive materials but worth it
05-07-2017, 07:37 PM | #4 |
One thing for sure..its RED..will look great when done
05-07-2017, 08:22 PM | #5 |
looooove red trucks. love em. never own em, can only seem to get three shades of green, but someday..
looks just bright enough!
05-08-2017, 12:40 PM | #6 | |
Bravo.
"Life is too short to drive a boring vehicle". Later, Wayne |
05-08-2017, 01:12 PM | #7 |
here
http://s1119.photobucket.com/albums/...evellePic1.jpg I don't know if this old link will work, but it sure was a pretty chevelle.
05-07-2017, 08:38 PM | #8 |
Looks great! Nice and straight too! Nothing replaces quality coatings...nothing!!
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
05-07-2017, 08:48 PM | #9 |
Hey thanks, just finishing a two year, 1500 hour frame off nut and bolt restoration. Was quite the saga but it's finally coming together. Tons of time spent making sure everything is straight, thanks for noticing. The big back window conversion went beautifully, if anyone has any questions about that I'm happy to help. It was actually one of the easier parts of the job. I agree with you about quality coatings. I learned the hard way that you can't skimp on paint materials.
05-07-2017, 09:18 PM | #10 |
Wow, that looks great right out of the gun. Definitely post some pics after it's done and out in the sun!
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
05-07-2017, 10:21 PM | #11 |
62lwbc10, I "LIKE" it. I painted my 302 (for us old guys, most say 5.0) V8 Miata, '95 Viper Red. So, I'm definitely a fan. When you cut and buff, it's going to be a "knock your eyes out" sorta deal!!!
05-07-2017, 10:51 PM | #12 |
is that solid clour or metalic?
05-10-2017, 06:08 AM | #13 | |
Lay it On - Us - How much - Prep Steps and then Coatings ? |
05-10-2017, 01:13 PM | #14 |
Hey Port and Polish you would be correct, there was alot involved. Mind you, I did not do the work myself, I hired one of the best bodymen and painters on the East Coast to do the work, but i was lucky enough to be there with him, helping where I could and documenting the work via pictures. Every square inch of every part of the truck was first sandblasted, inside and out and then painted with Epoxy primer (I had the luxury of doing much of this part of the job, I had x fine black beauty coming out of every pore of my body for weeks afterwards). Each panel was then individually straightened and body worked to make them nice and straight. I can tell you sometimess weeks were spent on one part to get it right. Once the plastic work was done, the panels were hit with a sealer (cant remember what) and then with high build primer. THe high build primer was then block sanded flat, then multple cooats of low build primer were applied, block sanding flat between each coat. With each subsequent coat, the panels got flatter and flatter until they were esentially perfect and completely flat. Final coat of primer was white as this was important to make the Viper Red really pop [Note Viper Red has a bit of transparency to it and Ive had experiences with using darker primer colors and the results are not good. For Red, you need a light, preferably white primer to make the color really pop, otherwise, more orange overtones are present]. I wanted a very high end paint job, with deep clear that you could swim in and I wanted the clear to be very flat, with no orange peel whatsoever. I showed a number of pics to the painter to give him a sense of what I wanted and his response was "for this color and for that kind of finish, we need to use Glasurit". So we used Glasurit base and clear. I think the base was some crazy price, like 600 a gallon and the clear set up was also very expensive. Lets just say I have thousands in paint materials alone. Red is not cheap. [Note again, in a previous life, someone tried to convince me that spending alot of money on base was throwing money away. He was really experienced, old timer with alot of nice cars under his belt so I listened to him. We bought really cheap base, PPG Omni, and it was a complete disaster. Word to the wise, especially with reds, you get what you pay for]. Viper Red is code PRN.
5-6 coats of base and then 4-5 coats of clear. Sanded I think with 1000, 1500, 2000 all the way to 4000. THen buffed with a couple different pads (wool and foam) and a couple different polishes to get the final product. I had no idea just how much work was put in to just the sanding of the clear. Many many hours. THe original idea was to sand the clear and then clear AGAIN, but with this Glasurit clear there was no need to put more material on than is necessary, the clear coat is just amazing, any deeper or glossier would look goofy in my opinion. THere is such a thing as overdoing it. My buddy has a 57 chevy he did in Viper Red over Indian Ivory that is award winning and just amazing, so I got the idea from him. I have Indian Ivory accents in the interior to break up the red (like a Cameo) and my wheels will be powdercoated Indian Ivory as well. Cant wait to see it done!! |
05-07-2017, 11:27 PM | #15 |
Wow 62, looks fantastic. I absolutely LOVE it. Huge congratulations. I'm over the moon about my new red paint job too. Can't wait to watch it go together.
Man, red IS expensive. Holy moly.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
05-08-2017, 08:14 AM | #16 | |
05-08-2017, 08:58 AM | #17 |
Yeah a lot of people saying that and I agree it does have a candyish look about it. But it's just a solid color, no metallic.
05-08-2017, 09:02 AM | #18 |
Door after sanding up to 4000 and then polished. Not too shabby.
05-08-2017, 09:55 AM | #19 |
Daaamn that's nice. That truck's gonna look good.
05-08-2017, 10:05 AM | #20 |
Nice, I'm just a little ahead of that stage, red also only darker. After looking at primer forever the paint is light at the end of the tunnel, now you can really see what it's going to be.
56' 3100 shortbed |
05-08-2017, 12:08 PM | #21 | |
I just worrried I might tire of the bright colors as I intend to keep my truck long term (til I croak, and I'm hoping that's long term!) ^^^This was not cut or polished, right out of the gun.^^^
05-08-2017, 12:28 PM | #22 |
daaaaaaaaaaaaaaaaaaaaang! that's nice
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-08-2017, 01:19 PM | #23 |
That is nice. Great to see someone go to the effort to have a top rate paint job and a really nice finished truck.
05-08-2017, 01:23 PM | #24 |
looking absolutly fantastic dan ......paint came out amazing !! it'll be a great runner
05-08-2017, 02:32 PM | #25 |
Looks great Dan. Very nice
