Old 05-08-2017, 03:11 PM   #1
jbgroby
jbgroby's Avatar
60-66 Radiator Over flow tank
Hey Gang,
I’ve been speaking with another member (Pete Chronis) on what was the factory correct radiator overflow container for our 60-66 trucks. I have ordered a generic 2”x16” container to catch my water expansion when needed for now.
According to what we can see or find, most trucks (65-66) came with a larger radiator overflow tank. Classic Parts #78-416 and is reported to fit ’41-54’. This mounted on the right inner fender next to the battery. However, it’s the same design as what was used on a 65-66.
Does anyone in the group have better information?
jbgroby is offline   Reply With Quote
Old 05-08-2017, 05:37 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 60-66 Radiator Over flow tank
I don't think I have ever seen a truck of this era with a factory overflow tank. Most everything has been just vented. Even my '72 El Camino doesn't have one.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-08-2017, 06:20 PM   #3
Classic v6 GMC's
Classic v6 GMC's's Avatar
Well I had to change my response because I found the picture posted below.
Still I have not seen a chevy with one even on our factory a/c trucks.
Maybe they were a dealer installed item.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 05-08-2017, 07:05 PM   #4
Classic v6 GMC's
I started thinking about it and had saved this picture some years back of this 66 GMC Suburban with Factory Air Conditioning. Not sure if the tank is factory or an accessory.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 05-08-2017, 08:59 PM   #5
64shortbox
64shortbox's Avatar
I'm not sure if you are looking for a factory overflow tank (I've never seen one) or one that looks factory and fits our trucks. - If you are looking for an overflow tank looks good & fits our trucks you might look at the ones for the Ford Trucks. They are a Radiator Over Flow/Windshield washer combo and the cut of the tank fits the angle of our inner fenders almost perfectly and as a plus you can now add windshield squirters at a later date if you want. This is the set up I went with on my 64 C-10. I moved the horn relay and voltage regulator to the other side of radiator support using the original mounting holes and grommets for both. I later though did go to a one wire 120 amp alternator. I got mine from the wrecking yard BUT you can get it brand new from Rock Auto for $28.00 if you prefer to go that route.
Rock Auto Overflow
http://www.rockauto.com/en/catalog/f...ery+tank,10457
64shortbox is offline   Reply With Quote
Old 05-08-2017, 11:13 PM   #6
damnyankee36
damnyankee36's Avatar
Uh, you're using a what? ;-)
damnyankee36 is offline   Reply With Quote
Old 05-08-2017, 11:20 PM   #7
damnyankee36
Old 08-02-2017, 07:12 PM   #8
Ken Cook
Ken Cook's Avatar
Rock Auto Overflow
Do you know year model truck this came from??
Ken Cook is offline   Reply With Quote
Old 05-08-2017, 10:51 PM   #9
damnyankee36
Old 05-09-2017, 11:18 AM   #10
60-66
60-66's Avatar
Chevrolet did not offer an overflow tank for 60-66 and I cannot find any supporting info for GMC. The one you show Jake is a reproduction of the factory one for Chevrolet of the 40s and 50s. The one in post 4, I dont believe to be factory judging by the mounting bracket. Pretty sure thats Steves Suburban.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 05-11-2017, 11:24 AM   #11
60-66
60-66's Avatar
.delete
Old 05-11-2017, 03:16 PM   #12
f66
f66's Avatar
My 66 has what looks like an add on of unknown vintage.
f66 is offline   Reply With Quote
Old 05-12-2017, 11:14 AM   #13
oldusafmsgt
oldusafmsgt's Avatar
I have the dealer truck data books for 60-66, a radiator overflow is not listed for any year as a factory option or an accessory.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 05-12-2017, 01:57 PM   #14
60-66
60-66's Avatar
Do you have any of the GMC Data books ?
Old 05-12-2017, 02:22 PM   #15
oldusafmsgt
No, sorry, I don't. The Chevy data books are hard to find, and can be expensive, and the GMC books even more so. The last GMC book I saw, a 1963, sold for $300.00, and that was 4 years ago.
Old 05-12-2017, 02:40 PM   #16
60-66
60-66's Avatar
Oh I know , I have every data book 1955-1970 but only 4 GMC data books. Priceless information that took a long time to find. But to confirm what you stated , the GMC and Chevrolet parts books do not list a radiator overflow can .
Old 05-12-2017, 02:47 PM   #17
oldusafmsgt
I have no idea what the GMC books say about a radiator overflow. In my 60-66 Chevy data books, I can't find a reference to one, either as a factory option or dealer installed accessory. I'm sure, like rear bumpers those years, dealers probably offered some aftermarket catch can if someone wanted one.
Old 05-14-2017, 09:57 PM   #18
reed62
reed62's Avatar
Originally Posted by jbgroby View Post
Hey Gang,
I went with an early 1990's Toyota overflow tank. Nice and narrow and mounted it on the driver's side radiator support.
reed62 is offline   Reply With Quote
Old 05-14-2017, 10:38 PM   #19
'63GENIII
'63GENIII's Avatar
Rock Auto Overflow
Got the same set up thanks to you 64 Shortbox. Cleanest set up, especially for the price that Ive seen yet.
Why not? There's a ton of guy rockin Honda door seals that work better than anything else thats available to us. Heck, the AC in my '63 is out of a '62 Chrysler
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 05-21-2017, 10:43 PM   #20
65chevysub
65chevysub's Avatar
Reed62. Do you have any pictures of your overflow tank?
65chevysub is offline   Reply With Quote
Old 05-21-2017, 10:58 PM   #21
reed62
reed62's Avatar
Yep....Here it is. It sits pretty even with the top of the radiator support and I used another Toyota bracket from a Sequoia overflow tank and bent it around to fit this tank.
Old 05-21-2017, 11:04 PM   #22
65chevysub
65chevysub's Avatar
Thanks. I like the small size and can mount it where my old square "brick" was.
Old 05-21-2017, 11:11 PM   #23
reed62
reed62's Avatar
Yep and when I found it I grabbed it. It should have enough capacity to hold what little liquid will make its way to the tank. For $9 it was a done deal in my book. It was off a pickup by the way. Not sure if the cars have the same style or not. The little extra tube that points down is used for the venting feature.
Old 05-14-2017, 11:41 PM   #24
CRUZN66
CRUZN66's Avatar
Hey Gang,
Here's how I mounted mine.
CRUZN66 is offline   Reply With Quote
Old 05-15-2017, 12:30 PM   #25
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
http://67-72chevytrucks.com/vboard/s...light=Overflow
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
