ls swap, 4l80e acting funny
Current setup:
6.0 LS with a bigger cam and springs. 4l80e with circle d 3200 stall converter I didn't go through the transmission when I got it. I was told it ran well and shifted fine. During my first few test drives it just seems like the trans wants to shift to 4th and overdrive wayyyyy too quickly. I bought the computer separately and will have to get it tuned. It was in another swap before mine. I'm just starting to freak out about getting this transmission rebuilt. my question is: while tuning ( I know nothing about tuning) can the tuner adjust the trans control to pick different shift points? I'm assuming tire height and rear end gearing has a lot to do with it. Or Is this a serious problem that I should go ahead and fix before throwing more time and money on different parts of the project. I'm 95% complete |
meowMEOWmeowMEOW
Re: ls swap, 4l80e acting funny
yes
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
You have the TPS working correctly? The trans needs to know the throttle position (load). Otherwise it's going to think your throttle has always returned to idle and it'll upshift early.
I'd expect the "default tune" to be close, but all bets are off until you've set up the computer, really....
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
TPS is a new sensor and im using a PSI harness.
![]() Join Date: Apr 2005
MORE than likely the wrong gear and tire size is in the tune which is throwing everything in your transmission tables off.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
