05-15-2017, 12:37 AM | #1 |
Air Cleaner Blues...
Im having issues with the air cleaner on my 69. I bought it with some little aftermarket one on it and Id like to get an original air cleaner and spacer together. The air cleaner i have isn't quite right, and I believe I could use a spacer. I have a tube/hose coming out of the passenger side valve cover close to the firewall that doesn't line up with the port on the air cleaner. It is a 2 barrel and I don't have a spacer. Heres what i got if someone could tell me what I need..I think (correct me if I'm wrong) I have a set up for a non ac pickup. but heres what Ive got.
05-15-2017, 06:40 AM | #2 |
Re: Air Cleaner Blues...
Why don't you move the hole for the breather. If it's round buy a step drill that will cover that hole size. If it's square drill small holes in each corner and cut out with tin snips. The old hole won't matter.
05-15-2017, 07:43 PM | #3 |
I have an original I think but it has a spacer. No pipes go to it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
05-15-2017, 08:03 PM | #4 |
There ya go.
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
05-15-2017, 10:49 AM | #5 |
My 1969 C 10 has the original air cleaner . Don't know how to post pics, tho . Let me know if I can help .
05-15-2017, 03:39 PM | #6 |
I don't want to go cutting and making new holes and making something fit while have a couple random open holes. If I'm going to do it, it's going to be done the way the factory had because I'm just a particular s.o.b. When it comes to original stuff. The rest of the pickup is all original from the factory so I'd like to have it stay that way. 697498Chevh if you could get a picture let me know
05-15-2017, 03:45 PM | #7 |
Be glad to take a pic . Can I text it to you ?
05-15-2017, 05:12 PM | #8 |
Heres mine, 350 with 4 barrel and ac. I realize the 4 may be a different setup than the 2 barrel. But maybe it'll help you some
05-15-2017, 05:30 PM | #9 |
Then buy the corect air cleaner.
05-15-2017, 06:03 PM | #10 |
05-15-2017, 06:13 PM | #11 |
Awesome pictures. Looks about the same as I need..could you possibly get a shot of the tube coming from the manifold. And on top of that manifold?
05-15-2017, 07:03 PM | #12 |
I've got the air cleaner /spacer/stove pipe you need pm me a # and I'll send you some pics
