Old 05-19-2017, 10:14 PM   #1
tim71
tim71's Avatar
Where does this go?
I can't remember where this belongs and can't see it in any of the photos that I took. It's not the piece that straddles an intake runner near the front of the engine on the drivers side, as I have already put that piece on. I took a lot of pictures as I tore my truck down, but I should have taken more from multiple angles. I assume it goes on top of the engine some where, that's why I painted it along with other engine pieces. Any help would be appreciated.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 05-19-2017, 10:20 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Where does this go?
passenger rear intake manifold bolt. Used for lifting engine
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 05-20-2017, 12:16 AM   #3
dfwright
dfwright's Avatar
Here's a picture for reference
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 05-20-2017, 12:24 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Unless you're doing a full on restoration... it's not needed.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-20-2017, 01:28 AM   #5
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I recall having at least one. Nice way to pull an engine I'd say, especially with a leveler.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-20-2017, 09:03 AM   #6
Katrina/10
Katrina/10's Avatar
They don't work well if you use a single chain to lift the engine, they will bend. I know that's not what they did at the factory.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 05-20-2017, 11:00 AM   #7
71CHEVYSHORTBED402
If I get your meaning, that's because of the force too close to a 180 angle. These require a 90, or near anyway.
Tony
Old 05-20-2017, 11:27 AM   #8
Katrina/10
Katrina/10's Avatar
From what I understand, the assembly line used a spreader bar with pins that go in the holes in the brackets, so all the lifting force is straight up. I tried lifting mine with a chain hooked between the two brackets and lifting in the middle. It caused the brackets to bend to the center of the engine. Obviously not ideal. They would work pretty well if you could rig up some sort of spreader between the brackets.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 05-20-2017, 11:38 AM   #9
dfwright
dfwright's Avatar
Load leveler works well with these lift points.
Old 05-20-2017, 11:44 PM   #10
71CHEVYSHORTBED402
I picked up similar, package deal on a hoist.
Tony
Old 06-12-2017, 08:00 PM   #11
71CHEVYSHORTBED402
Say, came across the lift bracket(s) off my 71. I knew I'd seen these. Couple questions/observations illustrated by the picture. Any knowledge appreciated.
Edit. At another look, none of mine are like the OP. Only one is like post 3.
Tony
Old 06-12-2017, 09:46 PM   #12
jocko
jocko's Avatar
I install em if have em - if I don't, I feel like I'm saying, 'go ahead, I dare ya to have to be rebuilt any time soon....' And the engine always wins.
Old 06-12-2017, 10:36 PM   #13
BlueBoy72
Active Member
The bracket with one bolt hole mounts on the back of the passenger side head
in the bolt hole closest to the intake manifold.
BlueBoy72 is offline   Reply With Quote
Old 06-12-2017, 11:52 PM   #14
El Dorado Jim
x2
El Dorado Jim is offline   Reply With Quote
Old 06-13-2017, 12:51 AM   #15
Classic Bowties
Always on the hunt...
Originally Posted by El Dorado Jim View Post
x2
Here are a few pictures of a 72 402 big block to go with the two above quotes. Mel
Classic Bowties is offline   Reply With Quote
Old 06-13-2017, 12:46 PM   #16
71CHEVYSHORTBED402
Nothing like confirmation, thank you. The top of your rear bracket looks bent like mine. I don't suppose that's on purpose.
Tony
Old 06-13-2017, 12:00 AM   #17
71CHEVYSHORTBED402
Per post 11 right? If so, then the config. would be the following. Two observations. That puts the rear passenger bracket 1" below the bracket on the front driver's side, and man that's close to the firewall. I'm no expert handling engines by a long shot, but at a glance, I'd never use the rear bracket. Too close.
Tony
