1951 - 5 Window
Finally got the build underway... Only took 2 years. Plan is to rebuild the chassis with a MII front end and Tri 4 link in the rear. Still cant figure out if i want to put in coil overs or air ride. Any recommendations? Then drop in an engine (383), all new drive train (Tremec 5 speed or 700R4), and a repair floor pans and redo inside of the cab.
![]() ![]() Join Date: May 2015
Re: 1951 - 5 Window
Looks like a decent truck to start out with..I'm using coilovers on my truck..personal choice..I don't want to have to deal with the expense and all the compressors and tanks associated with air..mines going to get driven a lot if I ever get done with it..interesting front bumper and grill guard..what is it? Got any pics of it..
#3 | |
Re: 1951 - 5 Window
![]() Join Date: May 2007
Re: 1951 - 5 Window
looks like amazing condition for your area
Re: 1951 - 5 Window
Ya its not as bad as some that I have seen from around here. Took me a couple years of hunting to find one without so much rust. The guy I bought it from said his dad kept in his barn for 20 some years. It has your typical rust spots; floor pans, cab corners, lower cowel and kick panels but outside of that its a good candidate to be resurrected and back on the road . Still haven't gotten it all the way tore down so we shall see if there are any more hidden trouble areas.
Re: 1951 - 5 Window
Here are the some pictures of the front bumper.
Re: 1951 - 5 Window
Got some more work done this weekend. I was going to take off the axles, however, I read somewhere that you should mark your axle center lines before. My plan is to put in a triangulated 4 link in. Can anyone shed some light on the subject??
Re: 1951 - 5 Window
That is a interesting bumper..does it look homemade or what?...you planning on using it.?..
Yes mark the frame where the axle centerline is just for a reference..you may want to move the axle a little to center it in the wheel opening but at least you'll know where it was..most crossmember manufactures will give you a reference point on the frame of where to center it ,,something like.. ( measure 3.125 inches from this hole to this mark).. on the rear get your axle in place and square..measure measure measure..when you get it right front to back and side to side up and down ..weld some temporary bracing to it to hold it in place and then start installing the 4link..what rear axle are you going go use? Also I spy a nice lookin chevy ll.. |
#9 | |
Re: 1951 - 5 Window
Good eye on the Chevy II, that's where my affinity for car building began at the age of 6, following dad around the shop. |
Re: 1951 - 5 Window
A zr2 rear is a good option if you can find one..comes with 3.73s and g80 locker..hard to find though..keep in mind the zr2 is 3in wider than a standard s10 but matches the ad trucks width close..
Very nice duece...always had a soft spot for those |
#11 | |
Re: 1951 - 5 Window
#12 | |
![]() Join Date: Apr 2009
Re: 1951 - 5 Window
Desert |
![]() Join Date: Mar 2010
Re: 1951 - 5 Window
Sub'd, Nice project.
Re: 1951 - 5 Window
I'll tag along.
1949 - 3600 Update suspension, engine and drive it. http://67-72chevytrucks.com/vboard/s...d.php?t=691034 1953 - 3100 1955.1 - 3100 Bare Metal Build http://67-72chevytrucks.com/vboard/s...d.php?t=691261 1965 - Buick Special & 1965 Buick Skylark |
#15 |
Re: 1951 - 5 Window
Nice truck!! I have air bags and love them, takes a bit to get used to them but now I just hop in and go.
As for the 4-link, get some reference measurements off the frame now while it is together. Then when you go to place the rear end for the 4-link have the frame and axle on jack stands, get it all in position and start tacking your brackets.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
