05-23-2017, 02:01 PM | #1 |
Vintage Air
Ok I have Vintage Air on my 1969 C/10 the problem is when i turn on the A/C the belt squeals is there a different bracket that i can use so i can move compressor forward 1/2 in so I can use two belts or any ideas
C/10 John N.J. |
05-23-2017, 02:07 PM | #2 |
Re: Vintage Air
One belt on the compressor should be good. Do you have it adjusted properly? Do you need to get a smaller belt, so you have more adjustment range?
Also, is the belt the correct width and depth so that it rides all the way into the groove of the pulley without bottoming out in the pulley?
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
05-23-2017, 02:09 PM | #3 |
Re: Vintage Air
I have Vintage Air too. Never had a problem with running a single belt to the compressor. Make sure the belt squeal is not coming from your alternator. The A/C will put a load on the alternator that will generate internal resistance that could cause a loose alt belt to slip. Also make sure you are running the proper belt on the compressor. If the belt is too narrow, it can bottom out in the compressor pulley and cause the belt to slip. You always want the belt to seat on the sides of the pulley grove, not the bottom. Hope this helps.
05-23-2017, 02:13 PM | #4 |
Re: Vintage Air
Is your current belt lined up "straight"?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
05-23-2017, 03:07 PM | #5 |
Re: Vintage Air
here's what we look like
C/10 John N.J. |
05-23-2017, 04:21 PM | #6 |
Re: Vintage Air
If you have a fan clutch that is locked up it will put a heavy load on the belts. If the a/c system is over charged or the fan is weak it can put excess load on it. If none of these ideas work put a gauge on the high side & see if the pressure is excessive.
05-23-2017, 08:45 PM | #7 |
Re: Vintage Air
We'll give all the above a try
C/10 John N.J. |
05-26-2017, 09:48 PM | #8 |
Re: Vintage Air
I had the same problem with my vintage air squeaking, slipping etc. After trying different belts/lengths angles etc, I called vintage air. They told me my belt was too narrow...that I need a 1/2" wide belt. I was skeptical, but the new replacement belt worked great. The belt actually rides a little bit above the pulley (see pic). Vintage air rep said that's how it should be. My belt is NAPA part # 25-9540 and it's 31/64" wide and 54-3/8" long. Works great.
_____________________________________________ 1972 C10 - SWB /383 stroker/Th400/3.73/vintage air |
05-26-2017, 09:53 PM | #9 |
Re: Vintage Air
Forgot picture....
