05-26-2017, 08:44 PM | #1 |
Why am I going through Ignition modules?
Had to replace my ignition module again in my 86 305 GMC pickup. Why do these go out? I have a friend that owns his own shop and he said when he had a truck like mine he was always replaceing his IM.
I replaced the original distributor and it still does it. I thought I had it fixed by cleaning the contacts on the wires going into the cap but after about a year this ignition module gave it up. These modules are AC Delco! I have had them go out going down the highway and in town driving. This one went out after it started! Any suggestions how to stop burning these up? |
05-26-2017, 10:16 PM | #2 |
Re: Why am I going through Ignition modules?
had a old k5 blazer that did the same thing. after the second time i just kept a few in the glove box and the tools to change it on the side of the road. i eventually figured out that one of the coil wires on the top of HEI set up was barely stripped and was arching off to ground and that was causing them to blow, cant believe it took me that long to figure it out. so basically take off the plastic cover on the top of the distributor cap and start the truck and see if you see any arching
also check your tach output too, if its hooked up make sure its not grounding out either ive had square bodies since 1998ish and due to one of those IM going out on me on the highway its the one and only time ive had to have one on a tow truck as i didnt want to fix it on the side of the highway |
05-26-2017, 11:03 PM | #3 |
I got a non-coil type of cap from Summit Racing and mounted a coil on the intake manifold. I guess the in-cap type of coils get hot and burn up the ignition modules
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
05-27-2017, 12:19 AM | #4 |
Thank you, abig84 and 1968k20. I'll check the wiring. 1968k20 would you tell me more on the external coil? How did you wire the coil? Did you take out the module in the distributor? I would like to go this route? Thanks again both of you.
05-27-2017, 01:11 AM | #5 |
Stock coil or aftermarket hi-capacity coil?
05-27-2017, 06:39 AM | #6 |
I have a yard full of Chevys and haven't had a module failure in 10 years. They do fail once in a blue moon but not every year. Even my Skip White distributors are running the original modules. Are you using the heat sink goop under them?
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
05-27-2017, 07:46 AM | #7 |
Yes cadillac_al, I am using the white heat sink goop. Thanks
05-27-2017, 08:40 AM | #8 | |
but for good measures i still have one in the glove box |
05-28-2017, 06:29 AM | #9 |
You do need the heat sink compound.
If you can find them Delco modules have better internal buffering against electrical shock. Plug or coil wires that are 'marginal' will 'shock' the module. And aftermarket does not mean good. Worse set I ever has was a set of Accel wires. One bad, would still fire but would pop a module every now and then. Particularly cut-to-length if the ends were not cut and crimped with he correct tool. I now run GM wires whenever I can.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
05-28-2017, 08:17 AM | #10 |
make sure you have a good ground between the battery and motor, and motor to body, and motor to frame also.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
05-28-2017, 01:28 PM | #11 |
You are probably missing the ground strap that either sits under the coil or the wire that screws to a post on the coil. The other end of the ground goes into the center of the 3 wire plug from the base of the distributor. This is what grounds the coil. With this missing it will blow the module all the time
05-28-2017, 03:35 PM | #12 |
Thank you guys, I spent some time this afternoon cleaning ground wires. Thanks for all the good suggestions!
05-30-2017, 08:18 PM | #13 |
When I had that problem, I put new ground wires from the engine to the frame. Then I purchased a blaster 2 coil and an he I dust cover. Removes the coil from the cap and away from the module. I purchased this through Summit Racing.
06-11-2017, 08:49 PM | #14 | |
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
