05-28-2017, 11:06 PM | #1 |
mini truck racer
Lets talk connecting rods
Ok , I haven't updated my project thread because I have been racing and had 3 motors in and out of the truck in the last 2 weeks . I just bought a SHP block and have a 3.875 stroke crank . I have not bought pistons yet . I am planning on a 6 inch rod . I have carillo H beams and crower sportsmans in 2 other motors and im looking for suggestions . I looked at the callies and the Lunati rods . I also have 4 Olivers . All the rods look the same to me . Looking for a good quality rod , preferably American made , that will tolerate what im doing . Something like 650-700hp on motor . Shift at 7000-7200 . No more than 250 shot .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
05-30-2017, 10:03 AM | #2 |
Registered Truck Offender
Re: Lets talk connecting rods
I don't think you have much choice but to use a 6" rod. The crank counterweights force a high pin location,, = a 6" rod. A little piston rock at TDS is the tradeoff, but yu typically get a lighter piston which is a big + above 7000.
The Lunati is not the quality of the old LAD1 Lunati ProMod rods of the early 2000's. I burned one in the truck motor about 5 years ago,, ended up selling the 7 good ones and buying a new set of Olivers. The Olivers are good to 1000HP and I know one engine builder that uses them in his 9500RPM 1000HP heads-up SBC's. For the small $ over a lesser rod,,they are good insurance IMO. Everyone is making a cheap line of rod these days,, Just be aware the lesser line and the better line MAY be the same rod.... just more attention to final finish, fit, xx-ray, inspection, re-inspection..... It's like SRP and JE,,, One is tooled to 0.0001,, the JE is diamond finished to 0.00005. If the 4 Olivers you have are new,,, I'd order the other 4 and never blink an eye. 800+HP boosted @ 7500 deserves the BEST rod you can find IMO. I don't know that a used Olivers out of a comp eliminator motor is it??,, but if you know what abuse the rods may have seen,, having them X-rayed and checked is a hell of a lot cheaper than new obviously.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
05-30-2017, 12:07 PM | #3 |
mini truck racer
The 4 I have are in great shape I have 7 , but 3 are questionable . I think I can buy them new for around $230 each . That around $900 for a set of killer rods
05-30-2017, 03:12 PM | #4 |
For what it is worth, I have had Callies Compstars in my 418" motor (4" stroke) since I built it. They are a 6.125" rod
Guessing they have seen a true 1000hp at the crank Have had regular 7,200rpm shifts Occasional 7,500rpm shift Very rare 8,200rpm rev limit hit in the burn out box when I haven't driven the truck in a while
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
05-30-2017, 03:32 PM | #5 |
mini truck racer
OK , really want the conversation to continue , but I called oliver and have boxed up the 7 rods I have . For $75 they will inspect them and clean them and also let me know what it will cost to make a complete set . Still oliver cant be the only game out there . I also looked at the callies compstars . Look like good stuff for this 414 /415 build
