05-31-2017, 10:18 PM | #1 |
1957 Chevy Grumman Front Disk Brake Conversion
I usually stay on the 60-66 side but recently picked up a 57 Chevy Grumman van and was wondering what is the best way to convert the front to disk brakes.
Is the van front axle the same as a 3/4-1 ton truck axle? Any good disk brake kits? I want to keep the stock 19.5" Wheels. I found this bracket kit. Any opinions on it? Will it push the wheels out to far? http://www.thehollisterroadcompany.c...converion.html I have a 2003 Chevy 2500 van rear axle with disk brakes and 3.73 gears so just need to figure out the front. Thanks
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more Last edited by Classic v6 GMC's; 05-31-2017 at 10:48 PM. Reason: spelling |
05-31-2017, 11:49 PM | #2 |
Hollister Road Co.
Re: 1957 Chevy Grumman Front Disk Brake Conversion
Send me a picture of the front hub. wheel off. and I'll tell you if t will work
06-01-2017, 10:37 AM | #3 | |
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
06-01-2017, 09:12 PM | #4 |
Here are some pics
06-01-2017, 09:15 PM | #5 |
Pics
06-01-2017, 09:45 PM | #6 |
Hollister Road Co.
That hub uses our SRW kit. Its a standard single rear wheel front axle. On the dually truck there is an extended hub that sticks out about 6" from the drum.
06-01-2017, 11:28 PM | #7 |
Okay thank you for the reply. Before I purchase I need to do my home work on the other parts I will need.
06-02-2017, 01:08 AM | #8 |
Why do you need the discs? Again, I have to ask the question. Unless you are driving a lot on winding mountain roads you do not need disc brakes.
Forget all the "modern highway" BS you don't need disc brakes unless you are driving it on windy mountain roads or something like that where the drums get overheated. Just normal driving you don't need them. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
06-02-2017, 10:32 AM | #9 | |
Andy
06-02-2017, 01:12 PM | #10 | |
Brian
06-02-2017, 04:38 PM | #11 |
hey Brian, have you ever had to hit the brakes after one wheel goes through a big puddle, or both for that matter. not as good as discs plus they tend to pull. if it was me it would be discs already. haha
06-02-2017, 05:06 PM | #12 | |
I have to ask, what happened 40 or so years ago that changed everything? 40 years ago about 95% of the cars on the road were drum, it wasn't that many years before, 1970 or so where about 99.9% of the cars were drum. How did we survive? There must have been crashes on every street every day. Nope, there weren't, how in the hell did we survive. Brian
06-02-2017, 12:30 PM | #13 | |
Hollister Road Co.
The safety enhancements of disc brakes over drums are well known. The main one is if an outer wheel bearing fails on these trucks the wheel does not come off if its a disc brake. Disc brakes stop better with less maintenance, They don't fade in weather like drums and with the 2003 up parts this kit uses you can replace them in 10 years if you need to. Towing with a big van like he has its just a plain smart decision. Keeping up with traffic I one thing but you also need to be able to stop with traffic. |
06-02-2017, 12:46 PM | #14 |
pics or it never happened
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
06-02-2017, 10:19 PM | #15 |
Here a couple pics
When I am ready to start working on it I will create a build thread.
06-03-2017, 12:58 AM | #16 |
It looks like the windshield is made up of 6 pieces? A flat piece at the center and then a curved one with the flat one on the sides?
If that is the case those flat ones will be easy to change. The curved ones are a while different story but if you had the flat ones new it would be what you are looking threw most of the time and it would make a big difference. Brian
06-03-2017, 01:18 PM | #17 |
those curved glass pieces are probably rare as hens teeth
thanks for posting up the pics, that body looks pretty clean
06-03-2017, 01:45 PM | #18 |
Hollister Road Co.
I saw a few videos on how to make those out of Lexan. Seemed to be moderating easy but time consuming
06-03-2017, 09:45 PM | #19 | |||
Luckily I found a guy on eBay who sells the curved corner piece in Plexiglas for $75 each. Already received it and it looks good. The body is straight with just a few small dents and scrapes down the side.
06-04-2017, 01:47 AM | #20 |
I wonder if a hydroboost could work for the brakes. it would take less physical space.
06-04-2017, 12:53 PM | #21 |
easy peasy to get a mc in there
leave the pedals as are (clutch is optional ) cut off the old mc (leaving the pedal mount) and make a bracket to mount the new mc or hydroboost a foot behind the old mc make a new rod to connect the pedals to the new mc look at orrieg's build for ideas, my hydroboost is at the pedals, it is a little tight to everything orrieg has his mc 1 ft behind the pedals
06-04-2017, 09:35 PM | #22 | ||
06-04-2017, 01:26 PM | #23 |
Hollister Road Co.
12
06-05-2017, 11:16 AM | #24 |
What is the wheel base on the Van?
06-05-2017, 07:19 PM | #25 |
It is a "Shorty" at 104" or 108" (still need to measure it) and that is the reason we bought it.
