Old 06-05-2017, 01:02 PM   #1
Ahansen15
HELP! I've got a metal humming sound
HELP! 99% complete frame off restoration 1972 chevy K20, 402 BB (rebuilt), T400 Auto
Metallic sounding humming sound, constant between the speeds of 34-45ish mph. Does not change with gas pedal or what gear its in.
What's been addressed so far and ruled out:
-Transmission
-Rear-end
-Speedometer cable
-Tires, obviously...
-Open-ended tubes of metal side steps
Anyone had this random problem before, please help!
Thanks,
Asa
Ahansen15 is offline   Reply With Quote
Old 06-05-2017, 01:15 PM   #2
leftybass209
leftybass209's Avatar
Re: HELP! I've got a metal humming sound
Welcome!!!
Where is the sound coming from?
Have you had a passenger sit in the truck to help identify where it's coming from?
Have you driven by a wall, or a large flat building? (that helps to isolate a particular side of the vehicle)
When you say you addressed those parts, what do you mean?
An addressed transmission to me, is a 100% iron-clad ruled-out diagnosis, or a complete rebuild.
One thing you can consider doing is buying or borrowing a GoPro camera. Mount it somewhere you think the noise may be coming from, then take the vehicle for a drive. the onboard microphone may help to amplify the sound and isolate the issue.
leftybass209 is offline   Reply With Quote
Old 06-05-2017, 01:46 PM   #3
StepSide1965
Hood springs????
StepSide1965 is offline   Reply With Quote
Old 06-05-2017, 03:27 PM   #4
weq92f
weq92f's Avatar
What about Neutral?
Same thing when you free rev to 2500 or whatever 35-45ish MPH translates to in RPM?
If only happens in gear and driving then:
o Front end rotating components ( bearings, drums, etc. )
o link between end of tranny and rear end
o Rear end rotating components ( axles, bearainigs, drums, etc ).
Otherwise, should be easy to find!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
