06-05-2017, 02:58 PM | #1 |
Upper control arm hardware kit?
I found the oversized U bolts for the lower control arms but I am having a hard time finding upper control arm mounting bolts....
Anyone have a link or a part number for them?
It's what you learn After you know it all that counts! |
06-05-2017, 03:22 PM | #2 |
Never Ending Projects
Re: Upper control arm hardware kit?
Is there a problem with yours? Unless damaged, they don't normally get replace and the uppers don't have the major load on them like the lowers do.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
06-05-2017, 05:10 PM | #3 |
No problem. I just want all new hardware in the truck.
06-06-2017, 10:26 AM | #4 |
Well in looking, keep in mind these are splined shank, not normal bolts. They press into the upper mount. I know they are available but don't recall where I have seen them. You might check a local alignment shop, if you can't find them.
06-06-2017, 12:10 PM | #5 |
Moderator
Something like this? http://fasteners.nationalbolt.com/vi...carriage-bolts
06-06-2017, 12:42 PM | #6 |
I would think suspension parts are grade 8
06-07-2017, 12:18 AM | #7 |
60-66 Nut
If you want to replace the studs for the upper control arm mounting, I think you may have to buy them from GM. Personally I wouldn't worry about replacing them unless they are damaged. I would though get new all steel locking nuts for them.
06-07-2017, 08:09 AM | #8 |
I think this is what I am going to do. I'm just anal about using new parts so it's a "new" truck
06-07-2017, 01:24 PM | #9 |
Another Question...
Bought new nuts and lock washers for the upper control arms. The only thing I can find locally is grade 5 since they are fine thread. Is grade 5 fine for the upper control arms? Can I use a lock washer or do I Have to go back with something like the original lock type nut?
06-07-2017, 04:40 PM | #10 |
Ideally you want "top lock" nuts. The last couple threads are deformed so it's a mechanical locking. Split washers can lose their tension and allow them to loosen.
That said, I am sure there are 10's of 1000's of cars/trucks running around with regular nuts/lock washers. Grade 5 is okay for the top arms, as they don't see a heavy load but I tend to use Grad 8 for everything.
08-30-2017, 10:53 AM | #11 |
Would you happen to have the size on the nuts for the upper control arm? I need to replace mine upon re-installation of the arms due to corrosion.
Thanks! |
