lowered truck rides rough rough, need help
Hi All
My truck has all new stock suspension, shocks etc, except springs. it has been lowered, not exactly how, but guess shorter springs since all the other suspension parts are stock. need advice on how to get a softer smoother ride, i looked at our FAQ site but did not find anything here are some photos so you can see the ride height. http://s958.photobucket.com/user/al1...?sort=3&page=1 thanks Allan |
It's Better With Nitro
Re: lowered truck rides rough rough, need help
Usually, shorter springs are stiffer, but I would check your shock absorbers to see if they have enough travel (make sure they do not bottom out before the suspension reaches full travel). Ride comfort/quality is subjective, especially with our trucks.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
If it is lowered a lot in the rear it might need shock relocators or it might be riding on the bump stops. The link in your post did not work for me.
#4 | |
the photo bucket link should open, not sure whats wrong, some measurements; center of hub to wheel well lip front 16 1/2 inches rear 11 inches all 4 bump stops have about 1 inch clearance. thanks Allan |
![]() Join Date: Aug 2004
Also what is the height of the tires. I had some low profiles that made things real rough!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
rear tires 29 inches tall 255/60R18
front tires 28 inches tall 255/55R18 |
If the bump stops only has 1 inch. Maybe its hitting going down the road.
