06-10-2017, 10:49 PM | #1 |
Looking For A Radiator
Well my stock 4 row developed a leak. Actually a couple of them. So I'm either going to get it fixed or get a new one,
how much is it for places to fix pinholes on a radiator? If that isnt the way I go and decide to get a new one, who sells a brass/copper radiator (4 row) inexpensivley? I see them on ClassicParts and Brothers for like 500. Holy crap. Thats insane. I dont want an aluminum. I'd rather have stock style.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
06-11-2017, 12:15 AM | #2 | |
The Older Generation
Re: Looking For A Radiator
LockDoc
06-11-2017, 01:32 AM | #3 |
Rockauto
I BELIEVE IN JOHN 3:16 |
06-11-2017, 03:34 AM | #4 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
If your handy with a propane or butane torch you can make most repairs at home. Acid flux and 60/40 lead/tin solder and your in business. You can google "radiator repair pics" and get some ideas on how to approach a repair. I like the little refillable butane torches for pin pointing the heat. I use it soldering and for heat shrink tubing. If your leak is visible like a crack or split in a crossover, use a toothbrush sized wire brush to clean the paint and shine the copper. Smear some acid flux on the crack, use a pair of needle nosed pliers to close the crack. Now your ready to apply the heat, a dab or two of solder and your done. "Nothing fancy"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-11-2017, 08:04 AM | #5 |
I just purchased a 4 core for mine. The manufacturer is called Northern. They are made in Willmar Minnesota. Our diesel mechanic has an account with them. $315 I had to modify the rubber inserts.
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
06-11-2017, 05:04 PM | #6 | |
06-11-2017, 08:46 AM | #7 |
i have a harrison 4core for a 4speed truck, i cant decifer the metal tag. didnt leak but to restore it they wanted like 500.00! (recore)
06-11-2017, 09:57 AM | #8 |
I got mine from Oreilly auto parts for around a couple of hundred bucks, lifetime warranty and metal not plastic
06-11-2017, 09:28 PM | #9 |
I'm interested - how did it fit? Was it a stock style or was it a generic aluminum radiator? I'd like mine to look very stock.
06-11-2017, 09:48 PM | #10 |
I've had them repaired in the past. It's usually a fair ( cheap ) price and in my experience, worth the wait for the savings. If you immediately pull it and take it to a shop, your turnaround time will approach the same as ordering new online. Plus you'll save bookoo buck!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
06-11-2017, 10:30 PM | #11 |
Rock auto you can get a direct fit 4 row for about $130 and fits like the original.
06-12-2017, 12:47 AM | #12 |
You can patch up a 40 something year radiator and may luck out. Or you could have to pull it again annd again fixing leaks. I would get a new one.
06-13-2017, 01:29 AM | #13 |
I bought a brass and copper 4 row radiator from Rock Auto last year. I haven't used it as it sits up too high but I am going to hang onto it. It was on closeout and priced cheap, let me try and find the link.
http://www.rockauto.com/en/parts/vis...,radiator,2172 I am hanging onto my original radiator and later on I am getting it recored. I ground out the rivets holding my 4-row lower radiator brackets to the core support, I did that so I could use machine screws to bolt the brackets back in. That way I could replace those with the smaller brackets and put my recored radiator back in if I so decided. |
06-13-2017, 08:55 AM | #14 | |
06-13-2017, 09:09 AM | #15 |
I bought mine from Auto City Classics and switched from a 4 core to a 2 core. Check them out..
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
06-13-2017, 12:24 PM | #16 | |
Now in my case, one of the lower retainer brackets had been smashed in, making that side a 3 row radiator bracket. That kept it from fitting and made it sit up even higher. I have since rectified that but not before I bought an all aluminum 3 row radiator. Originally, my truck had a 1 or 2 row radiator that didn't sit on lower brackets at all! It sat on a piece of long, thin rubber placed on that lower shelf of the core support. I haven't reassembled my front end yet, I could still put in that (all copper and brass) radiator if I wanted to. I don't need that much cooling with just a 250 I6 though. |
06-13-2017, 12:33 PM | #17 | |
06-13-2017, 12:37 PM | #18 |
Forgot to mention. Mathematically, a 2 row radiator with 1" or larger tubes should cool more efficiently than a 3 or 4 row radiator with smaller diameter tubes. Now, I've seen plenty of small tube 3 or 4 rows cool engines just fine depending on climate and use, so take it FWIW.
06-13-2017, 10:29 AM | #19 |
JohnR has one for sale in parts-I was gonna buy it but exchange rate kills me
http://67-72chevytrucks.com/vboard/s...d.php?t=739222 |
06-25-2017, 11:35 AM | #20 |
I just discovered my radiator is leaking also. Already removed and am now trying to decide if I want to fix it or just get a replacement. There's a reputable radiator guy here in town and my gut says take it to him. However, does anyone have any experience with the ones that Wes offers on his site? $389 for an OEM replacement is within my price range.
06-25-2017, 06:12 PM | #21 | |
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-26-2017, 12:38 PM | #22 | |
06-25-2017, 01:01 PM | #23 |
I've been looking at radiators as well. I have the original 2 row and have been thinking about getting something that would cool a little better, I've got a question for you guys that have switched over to 4 row radiators. It looks like I'd need different upper mounts and to move the lower, but is the shroud the same or would I have to find a different one?
06-25-2017, 01:12 PM | #24 |
Imho, do not scrap out your old brass and copper radiators. The tanks on the sides are what is valuable. I had a local guy rebuild mine with a heavy duty forklift core for a decent price.
Cools like a dream! I would not use a aluminum unit on these old trucks unless its a show piece. You cannot clean the insides of them with the radiator flushs on the market today. EPA had made most radiator flushs reduce the harmful environmental chemical to using Sodium Citrate as the main ingredient. In the days when these vehicles where developed we used a chemical called Oxalic Acid which is harmless to brass, copper, and cast iron. It eats red oxide, which is rust! |
06-25-2017, 01:21 PM | #25 | |
Tags |
brass, copper, radiator |
