06-12-2017, 01:30 PM | #1 |
1970 Jimmy Heating and AC opinion needed
Vehicle is a 1970 Jimmy with factory A/C. Has round ball vents in dash facing passengers. The vehicle is missing all components to A/C system except the heater boxes under dash and engine compartment. I don't plan on replacing the missing A/C components.
The dash has been brutally hacked up to install a CB and din style radio, which I am planning on returning to stock configuration. I am in possession of a non-A/C dash front and components. Questions are: Should I replace entire dash front so it is non-A/C correct or just the radio section? Would it be in my favor to leave the A/C ball vent section of the dash in place and somehow route vent tubes to these outlets for passenger comfort? All opinions or ideas are wanted, thanks in advance. JT. |
06-12-2017, 02:54 PM | #2 |
Re: 1970 Jimmy Heating and AC opinion needed
Do you still have a solid cap on it or a soft top?
06-12-2017, 04:14 PM | #3 |
I'm going to go with a soft top.
06-12-2017, 04:30 PM | #4 |
Then it's just as well you don't plan on getting the AC to work because it's useless with the soft top. IMO, I would replace the dash if it's as hacked up as you say. This way you'll be able to fix the CB damage as well as get rid of the A/C vent holes.I would also get rid of the A/C underdash and engine compartment box to clean things up and replace it with a non-AC heater box. You will have to clean up the firewall holes if you do this because A/C used different holes.
06-12-2017, 05:16 PM | #5 |
I was wondering if those a/c vent outlets on the dash would be nice for the heater/vent air. If not will go with full dash face replacement.
06-13-2017, 03:31 PM | #6 |
In a truck the heater lower vent and def. vents are more than enough for warmth but I too am in the process of switching to a non/ac box in my blazer and deciding what to do with the ac vents. the PO did a hack job on the engine comp ac box and gutted the internal box. lucky for me I have spare non ac boxes. just trying to figure out the a/c vents since there is only 2 holes to work with in the non a/c box...
06-13-2017, 03:37 PM | #7 |
I'm sure there is a "Y" splitter available somewhere. In my case, I was thinking it would be nice to have vents that I can direct the air towards the driver/passenger using the A/C dash vents. Maybe I'm thinking too much.
06-15-2017, 05:23 PM | #8 |
what does a non-a/c heater box look like compared to an a/c one?
'72 K5, known as 'the Fox.' |
