06-14-2017, 07:58 PM | #1 |
Mid Chasis Gas Tank
I needed a new gas tank anyway so I wanted to move it under the box. I did not want to mount it behind the axel because that is where I plan on putting the spare tire. Since I have the service box instead of a standard bed, this gave me room to put the tank in front of the rear axel.
A tank from a 1967 Mustang fit perfectly in this area, just needed a cradle to mount the tank to the frame. I welded a side filler neck onto the tank and ran the fill tube into the driver side storage bin. Finished it off with a magnetic fuel door and push through gas cap. It will still many months before I drop in a pump and get the engine fired up, but one more task checked off the list. |
06-14-2017, 08:03 PM | #2 |
Re: Mid Chasis Gas Tank
nice job, I wonder if that would work for my 63 long bed fleetside?
06-14-2017, 08:20 PM | #3 |
Very nice job!
I have a 1963 short bed fleet side. I also have a 1965 short bed step side. I refuse to install a tank between the frame rails at the back of the bed because I want to keep my spare tire there (under the bed). I've been kicking around the idea of putting a gas tank in the bed just behind the bed header panel. Basically, install a tank between two header panels at the very front of the bed. It would get the tank out of the cab but would only sacrifice about 1 foot of bed length. I think it'd be more easily accomplished in a fleet side bed since it is wider. The tank would gravity feed just like the tank that is inside the cab. For a fleet side bed, you could even use the original tank since it will fit between the bed sides. Just thought I would share my idea.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 06-14-2017 at 09:45 PM. |
06-14-2017, 10:38 PM | #4 |
But Found Her 25yrs Later!
I also banged around the idea of putting the tank there.
As you all, I want to put my spare behind the axle. My other thought was to go with one of those skinny spares rather than a full size tire.
06-17-2017, 08:31 PM | #5 |
[QUOTE=Soyuz008;7967601]I needed a new gas tank anyway so I wanted to move it under the box. I did not want to mount it behind the axel because that is where I plan on putting the spare tire. Since I have the service box instead of a standard bed, this gave me room to put the tank in front of the rear axel.
A tank from a 1967 Mustang fit perfectly in this area, just needed a cradle to mount the tank to the frame. I welded a side filler neck onto the tank and ran the fill tube into the driver side storage bin. Finished it off with a magnetic fuel door and push through gas cap. It will still many months before I drop in a pump and get the engine fired up, but one more task checked off the list.[/QUOTE Good idea. |
