Old 06-15-2017, 06:50 PM   #1
55dude
55dude's Avatar
235 in a gmc
guys i have a 51 gmc with a 228 and have a 58 chevy 235, what do i need to put the chevy 235 in place of the gmc 228. i'm changing it to a open driveline using a T-5 behind the 235. thanks
55dude is offline   Reply With Quote
Old 06-15-2017, 06:56 PM   #2
73kay
Re: 235 in a gmc
I think you need a plate for the front of the engine to mount to the Gmc frame. My Gmc had it with a 235. I might actually still have it. Not sure about the bell housing mounts. Could/should be the same?
Andrew
1953 3100 292 T5
1985 K5 Blazer 350 700R4 208
73kay is offline   Reply With Quote
Old 06-15-2017, 08:01 PM   #3
mr48chev
mr48chev's Avatar
Re: 235 in a gmc
This is a GMC frame that I am using on my 48 to have a 1/2 ton long wheelbase frame. I'm stretching the cab but want to keep the stock length short box on it.
I'm not sure on the center crossmember bellhousing bolt thing. We put a 56 235 in a 53 truck and I am sure we used the 56 bellhousing on it. It may be just using the right motor mounts but it isn't rocket science.
Bolt the bellhousing to the crossmember first and then fab up the piece for the front mount to sit on. Maybe 73Kay can find the one he has and get a couple of photos.
My ongoing truck projects:
Old 06-16-2017, 06:54 AM   #4
Katrina/10
Katrina/10's Avatar
Re: 235 in a gmc
A thick steel plate between the crossmember and front engine mount works fine. If you don't have the dimensions, bolt the 235 in at the bellhousing and support the front of the engine under the oil pan. Is your 228 bad?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
