Old 06-27-2017, 10:24 AM   #1
Stude47
Looking for SBC Radiator WITHOUT filler neck
Hello,
I am new to the forum and seeking advice for cooling system setups. I own a 1947 Studebaker Pickup that was modified with a 350 SBC and a 350 TH. The current cooling system is aging and I was hoping to upgrade since I will be going through the exercise of replacing the system. Here is what I am looking for:
- Aluminum 3-Row Radiator with shroud and dual cooling fans.
I have a custom remote filler due to the small volume claim and would like to find a radiator that does not have a filler neck but has the capacity to fit A/T cooling lines into the side of the core as well. Basically I am looking at something like the below link, but without the filler neck.
http://www.ebay.com/itm/3-ROW-FULL-A...tYh~0I&vxp=mtr
Seems like a stupid question, but where do you find one of these? It seems that all of them that I have found so far have the filler neck. The total volume claim space is 32 x 18 x 3.
Thank you
Stude47 is offline   Reply With Quote
Old 06-27-2017, 12:53 PM   #2
jweb
jweb's Avatar
Re: Looking for SBC Radiator WITHOUT filler neck
I would try Superior radiator, they are US made and I'm very happy with mine.
http://www.wwwsuperiorradiator.com/
jweb is offline   Reply With Quote
Old 06-27-2017, 03:54 PM   #3
OrrieG
OrrieG's Avatar
I need to ask, where would the fill be? Usually the fill is at the highest point to minimize the chance for air pockets
Old 06-27-2017, 04:41 PM   #4
1project2many
I am unable to see the item in your link.
Is there a reason why you can't use a radiator with a higher pressure cap than what's on the remote filler neck? There are some factory vehicles like this and I have done it in my own projects.
1project2many is offline   Reply With Quote
Old 06-27-2017, 06:47 PM   #5
Stude47
***Picture Heavy***
Not a reason that I know of other than to eliminate a possible leak point? I am not very familiar with cooling systems. Below are some pictures of the current setup. The cap on the radiator is almost impossible to access which is why there was a custom remote filler installed. The body panels of the truck limit a lot of what can be used in the area. The current setup seems to underrated and overheats often.
Old 06-27-2017, 07:00 PM   #6
mr48chev
mr48chev's Avatar
Reading the Superior radiator add it looks like they might be wiling to work with a guy.
My ongoing truck projects:
Old 06-27-2017, 07:25 PM   #7
jayoldschool
Moderator
94-96 Caprice/Roadmaster/Fleetwood/Impala SS rad should work. Check the sizes on Rockauto. The pressure cap is on the remote reservoir, no cap on the rad tanks.
jayoldschool is offline   Reply With Quote
Old 06-27-2017, 09:51 PM   #8
1project2many
That setup reminds me of the V8 Blazer I was building. I put the radiator in a custom support which prevented access to the cap. So I used an upper filler hose from a 2003-ish Dodge Durango w/ 318 to get aq filler neck. The radiator got an 18 psi cap.
Wherever the catch can is attached is where you should use the lower pressure cap. You could use a 14 - 16 psi cap on the radiator and an 18 psi cap on the filler neck.
The Caprice radiator ir also a good idea. Volvos, VW and Ford vans are all applications I'm aware of that use a pressurized reservoir with no filler or cap on the radiator.
Old 06-27-2017, 10:03 PM   #9
mr48chev
mr48chev's Avatar
Just as 1project2many said put a good 18 lb cap on the radiator and done. With the remote filler you should be good. Probably not much more chance of it leaking than a hose connection and maybe less.
Old 06-27-2017, 10:25 PM   #10
Stude47
I am not very familiar with cooling systems so excuse the stupid question in advance. I currently have a 16 lb cap on the remote filler tube. So by putting a 18 lb cap on the radiator filler will prevent it from leaking? What will happen if I break the pressure on the 16 lb cap (open the cap)?
Old 06-28-2017, 01:29 AM   #11
OrrieG
OrrieG's Avatar
Well, now I know more than I did. Brain is fried from work load....
Old 06-28-2017, 05:15 PM   #12
1project2many
I didn't notice the overflow bottle attached to the filler last night. mr48chev gives the correct installation for your truck.
The 18 psi cap on the filler neck should not vent or leak although I'd probably look for one with a little higher pressure just to add insurance. If you open the 16 psi cap it will be just like opening a system with only one 16 psi cap.
Old 06-29-2017, 08:24 AM   #13
1952ssr
1952ssr's Avatar
You can get a late '90s models vette (w/LT1) radiator without a filler from rockauto for a really good price. I almost went that route but decided on one with a filler.
1952ssr is offline   Reply With Quote
Old 06-29-2017, 11:12 AM   #14
Stude47
Thank you for the tip. What was your reason for opting for one with a filler?
