Old 07-02-2017, 08:58 PM   #1
ron350
ron350's Avatar
Brass water pump fitting?
Does any one know where I can buy a brass water pump fitting like in the picture?
This fitting is for a ¾” heater hose to ½” pipe threads in the top of the water pump. Dorman sells this in steel under part # 56360 but they don’t list it in brass.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 07-02-2017, 09:10 PM   #2
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: Brass water pump fitting?
I haven't seen them in brass but Spectre makes them in stainless steel. I think I got mine from Summit.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 07-03-2017, 08:43 AM   #3
Mattchu60
Only place I could find one like that last year was from Ebay - all the parts stores just had steel ones. Mine has a barbed end on it instead of that smooth one. It works fine.
Mattchu60 is offline   Reply With Quote
Old 07-03-2017, 11:55 AM   #4
ron350
ron350's Avatar
Thanks for the replies.
So far I found two different brands on ebay but both only sell in packs of five for $18.00 up. There was one guy that would sell just one for over $50.00. LOL
Imperial Brass 92085
Brass Fittings 809J
Old 07-03-2017, 12:47 PM   #5
Desert1957
Desert1957's Avatar
How come you need Brass? I have one laying around that's OEM cast.
Desert
Desert1957 is offline   Reply With Quote
Old 07-03-2017, 02:30 PM   #6
ron350
ron350's Avatar
I don’t like to use parts that can rust if I have a better option.
Old 07-03-2017, 07:38 PM   #7
Jake Wade
Jake Wade's Avatar
Summit has stainless fittings like that, I have used them many times.
Jake Wade is offline   Reply With Quote
Old 07-03-2017, 07:43 PM   #8
Jake Wade
Jake Wade's Avatar
Example:
https://www.summitracing.com/parts/prs-1001
Old 07-03-2017, 11:09 PM   #9
ron350
ron350's Avatar
Jake thanks for the link but I need a ¾ inch barb.
I give up and will just reuse the old steel fitting.
Old 07-03-2017, 11:49 PM   #10
70K10Hunter
70K10Hunter's Avatar
find a hyd hose shop and tell them what size thread you want you can get it in brass but it will probably have barbs on it which will secure the hose better any way.
70K10Hunter is offline   Reply With Quote
Old 07-04-2017, 12:59 PM   #11
ron350
ron350's Avatar
Jake thanks that is the correct fitting that fits my truck.
Summit Performance SS Hose Fitting 1003.
Desert1957 thanks I found a brass fitting like in your picture for $7.00 + free shipping in ebay. I will try the $7.00 fitting first.
Old 07-04-2017, 03:09 PM   #12
franken
Try the yellow parts bins at NAPA.
