Old 07-04-2017, 09:54 AM   #1
markbritt
65 hood wont stay up - need shorter springs?
Just got my 1965 C10 back from paint and we find that the hood will not stay up. We used the original springs on the hinges and suspected they lost their tension, so I ordered a new set from LMC. The LMC springs are about 1/2" longer and, upon installation, these too will not hold the hood up.
Is there a source for 1) shorter hinge springs or 2) a company that can shorten these springs and bend them properly for installation?
Mark
markbritt is offline   Reply With Quote
Old 07-04-2017, 10:28 AM   #2
chevylookin
Re: 65 hood wont stay up - need shorter springs?
Did you pivot the brackets/hinges? It can be adjusted up and down to even the load of the hood and provide a little more tension.
chevylookin is offline   Reply With Quote
Old 07-04-2017, 07:53 PM   #3
markbritt
Yes, I did pivot them. The adjustments allow the hood to move a bit forward or backward for gap adjustment. This has nothing to do with the ability of the spring to hold up the hood.
Old 07-05-2017, 12:40 PM   #4
61K10
61K10's Avatar
the first set i bought would not hold up my 61 hood. (don't remember the seller.) I bought another set from Brothers and they work fine. The first one were bought about 4+ yrs ago. the new ones probably 2yrs ago.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 07-07-2017, 11:54 PM   #5
Joe Pass
Joe Pass's Avatar
I had the same issue and after the second set wouldn't hold the hood up I added universal springs inside the stock springs and no more sag....simple and available at a local hardware store....They have strong resemblance to the seat adjuster spring but only 7" from hook to hook
Joe
Joe Pass is offline   Reply With Quote
Old 07-07-2017, 11:58 PM   #6
Joe Pass
Joe Pass's Avatar
Here's before shot
Old 03-25-2018, 12:26 AM   #7
rvrfoot
What color is your hood springs? Are they raw steel?
rvrfoot is offline   Reply With Quote
Old 03-25-2018, 08:10 AM   #8
markbritt
I originally ordered my springs from LMC truck. I then ordered from Brothers Trucks and these springs were about 1" shorter - worked great.
