Old 07-08-2017, 08:18 PM   #1
GMC85HighSierra
GMC85HighSierra's Avatar
Chevy 350 V8 To Chevy Inline 6 Swap ASAP
Hello, I am looking at swapping out my 350 for a Inline 6, but I have some questions. It would be going in a 1975 Chevy K5 Blazer. Looking at information first to see if I want to buy an inline 6 for my truck.
-How good of an engine is an inline 6 compared to a 350?
-Is a 350 trans a good mate for an inline 6? If not, what automatic transmission do you recommend?
-Where does the motor mount up? What do the brackets look like?
-Are the 250 and 292 the best 2 inline 6's to look for?
-Do inline 6's get better gas mileage than a 350?
Would like to know this information as soon as possible. Thanks
GMC85HighSierra is offline   Reply With Quote
Old 07-08-2017, 08:56 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Chevy 350 V8 To Chevy Inline 6 Swap ASAP
Do you already have a 250 inline with all brackets, pulleys and carb?
If not, you might get off cheaper finding a used 350
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 07-09-2017, 01:36 AM   #3
Edahall
This tread might answer your question.
http://67-72chevytrucks.com/vboard/s...d.php?t=642267
If high fuel economy and inline 6 is your goal, then consider a Cummins 6BT.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 07-09-2017, 09:23 PM   #4
GMC85HighSierra
I do not have an inline 6; I already have a 350 in the K5 right now. I was just seeing other people's opinions on an inline 6 vs. a 350. Thanks
Old 07-10-2017, 10:37 AM   #5
68Timber
I know the pieces fit
68Timber's Avatar
I'm not an inline 6 guru by any stretch but I'm pretty sure the 292 is the better motor just because of the extra cubes. The 6 is a great motor, just no powerhouse. Plenty of torque down low where you do most of your driving, just not a bunch left if you put it on the mat. The TH350 will work fine with it, I'm pretty sure it was a stock option with the 6 in a square. What are you trying to accomplish?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-10-2017, 07:26 PM   #6
GMC85HighSierra
I was just trying to do something different with my K5. A common thing to see is a 350 engine and trans paired together. I don't see a lot of inline 6s' around, so I was thinking about putting one in my K5. Thanks
Old 07-11-2017, 08:09 AM   #7
moregrip
moregrip's Avatar
I think it's still cheaper to build a sbc 350 over and inline 6 but if you decide to build the inline there is a fairly decent community that supports their modification/parts.
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
