72 K10 LQ4 swap overflow bottle question
Now that I have been driving my 72 for a couple of days I noticed antifreeze coming out of the overflow tube of the stock rad after I park it for a few minutes. Truck runs at 196f per my scanner...do I need an overflow bottle? Truck didn't have one when I bought it. What are you guys using? Pictures if possible thanks!
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
Re: 72 K10 LQ4 swap overflow bottle question
For what its worth, I don't have one on my lq4. have stock fan clutch (no shroud) and it sits at 90c / 194f solid according to my Dakota Digital gauges. Overflow hose puked a bit after the first coolant fill and running but hasn't in the 3000km or so since.
You dont need an overflow bottle, but without one you cant fill the radiator all the way to the top. This is the reason original radiators have the full level a few inches doen from the top, there needs to be room for expansion when the coolant is warm. If you over fill it, it will just puke out the excess then when it gets to the level it can safely hold it will stop, this will be the full level.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#4 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#5 | |
Old member
I have always ran a over flow tank on all 3 engines. It's just a good idea.
Where I work they have security guards that check the parking lot regularly. If they see the same vehicle puking anti freeze everyday they will put a sticker on it. After several times they will not let you on site with the vehicle until it's fixed. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
