66 driveshafts
So I thought for sure my 66 gmc long bed would habe a 2 piece drive shaft but today i was going to unbolt the bed to remove it to start the bodywork on cab corners and got to looking and it is a 1 piece drive shaft .... did long beds come with one piece drive shafts or has mine been swapped out sometime in its life i just thought it was odd I always hear about 2 piece shafts on long beds and find out mine has a 1 piece
Re: 66 driveshafts
I have a 66 Chev C20 long bed and it's a 2 pc driveshaft.
One foot in front of the other
![]() Join Date: Aug 2008
Re: 66 driveshafts
My 66 LWB is a two piece as well. Is there a place where a carrier bearing was at some point?
60-66 Nut
Re: 66 driveshafts
I have seen 2 longbeds with a 1pc driveshaft from the factory. I really don't know what the deciding factor was.
#5 | |
Re: 66 driveshafts
Propshaft critical speed not just based on wheelbase but is also based on trans type (length), rear axle ratio, tire size, and engine type (larger engines allowing a higher top speed) AND/OR any strange resonances in that particular combination (camping out on that resonance will break the trans/transfer case tailshaft housing). One other comment - critical speed is not directly related to balance, but rigidity. When the shaft exceeds it's critical speed it begins to bow in the middle and swing like a jump rope. Hence the disturbance and durability concerns. You can get around it by going to a larger diameter steel tube - or more expensive alternative materials like aluminum, carbon fiber, an aluminum/carbon wrap, or exotic materials like "metal matrix" (aluminum impregnated with other metals) - or - the cheap way out is to limit the vehicle top speed via ignition or fuel cut off above a certain engine rpm. So - given two otherwise identical appearing trucks - there could be a tire difference that put it over the edge, or perhaps a different horsepower rating which would allow for a higher top speed, or some unseen bending resonance that shows itself during testing which would drive the truck to get a one piece shaft vs a two piece. A long wheelbase truck with a low (numerical) rear axle ratio spins the shaft slower and might get a one piece, but an otherwise comparable truck with a high rear axle ratio might get a two piece. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 07-20-2017 at 10:53 AM. |
Re: 66 driveshafts
So with the holes in this cross member could it be used for trailing arms if I had the arms the mounting brackets and a pan hard bar?
60-66 Nut
Re: 66 driveshafts
Yes.......
Re: 66 driveshafts
No places to bolt or mount a carrier bearing just a drive shaft straight from the trans to the rear end is all I got
Re: 66 driveshafts
what transmission do you have?
1961 chevy K10 my build is------------61K10 build |
Re: 66 driveshafts
Re: 66 driveshafts
Can you post a picture of the one piece shaft? I had one made several years ago, but it caused more vibration than it was worth, so I went back to my 2 piece.
Re: 66 driveshafts
I don't have one on my phone at the moment but I will get one and post it but now that you say that I do have alot of vibration when taking off in first or reverse or under a load going up a hill from a dead stop but goes away after taking off or picking up speed I figured it was the clutch going bad and not enough power from the engine dying down
#13 | |
Re: 66 driveshafts
Thanks for getting a picture. |
Moderator
![]() ![]() Join Date: Aug 2011
Re: 66 driveshafts
Your posts pics have been photo-bucketed.
#15 |
![]() Join Date: Feb 2010
Re: 66 driveshafts
1 pc a GMC thing?
#16 |
60-66 Nut
Re: 66 driveshafts
