Old 10-25-2003, 01:22 AM   #1
Guy Brooks
what trans fits
I am new to the boad . I have a SB 70 just swaped the I-6 and 3 speed for a 267 and short shaft auto from a 82 car (I know but it was real cheep) drive shaft was to short someone told me a long shaft would work with my old drive line so I swaped in a 350 long shaft trany now my drive line is 1 inch to long.I am having a shaft made but can anyone tell me what trans fits
Guy Brooks is offline   Reply With Quote
Old 10-25-2003, 06:43 AM   #2
JimKshortstep4x4
Talking
Welcome to the board from West Michigan!
I am wondering if you used the right motor mounts or have them in the right location as the driveshaft should have fit.
Good luck!
Jim
Old 10-25-2003, 09:45 AM   #3
Guy Brooks
Thanks I had not thought of that all the motor mount stuff came from 86 3/4 ton I thought all the mounts and tower were the same . I used the only holes that would line up.I am not much of a mech. I am lerning as I go lots an lots of rework.The trans did seem to close to the under side of the cab.I'll look at it with NO buget moving it all forward beats $100 bucks for drive shaft.
Old 10-25-2003, 11:15 AM   #4
krue
Designated A-hole!
krue's Avatar
May have to drill a few holes, or just find the right V8 mounts.
Mine has a short (6 inch) tailshaft TH350 in it stock. I have a two piece driveshaft on mine. With a little mod you can install any tranny 2004r, 700r4, Th 350, Th400, Powerglide.
BTW welcome to the board from South Mississippi! Post some pics of your truck!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 10-25-2003, 11:39 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
All right Guy, your truck was an original 6 cyl 3 speed truck right? It had a one piece shaft from the factory didn't it?
If you move the V8 to the proper forward location, AND use a 9 inch tailshaft TH350 tranny, the driveshaft will be the right length. The 9 inch tranny was used in 73 up trucks. Stock 67-72 trannys were the 6 inch version. Also, the 700R4 is the exact same length as the 9 inch TH350, so they swap straight in using the stock shaft too. Make sure you use the proper V8 mounts in the right location though!
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-25-2003, 12:21 PM   #6
gr8scott51
gr8scott51's Avatar
anything
I've found that anything will fit, if you get it going fast enough or use a big hammer!
Just kidding. Sounds like you already got some good advice.
Welcome from soggy western Washington.
good luck,
Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 10-25-2003, 10:01 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Welcome from southern oregon..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-25-2003, 10:28 PM   #8
jorgensensc
jorgensensc's Avatar
Welcome from SoCal (temporarily )
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-25-2003, 11:02 PM   #9
Denny
Denny's Avatar
Welcome from Missouri
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
Old 10-25-2003, 11:22 PM   #10
Guy Brooks
Thanks for all your help . I moved the motor mounts and cross member forward redrilled everthing just gotta go get more trany fluid and I can drive it after 3 months . Wish I had had access to this bord when I started. Will post pic's soon as I get a hold of the right kinda camara.Thanks again.
