Old 10-25-2003, 02:12 AM   #1
71Rat
ran out of money
71Rat's Avatar
will any 400sb fit a 700r4?
Hello all
I found a 400 small block out of a Pontiac and I was wondering if the bolts pattern and everything for the bellhousing to bolt up is the same as a chevy's? Thanks for all the input.
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 10-25-2003, 03:51 AM   #2
1969 GMC
1969 GMC's Avatar
i do believe BOP (buick/olds/pontiac)(cadillac too) motors had a different bellhousing pattern than chevies.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-25-2003, 05:15 AM   #3
68 Suburban
68 Suburban's Avatar
I think that is correct. The pontiac 400 will not bolt directly to a 700r4. I think if you find a 200r4 you will be in luck. I think that trans has both bolt patterns.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 10-25-2003, 06:57 PM   #4
dinnut
dinnut's Avatar
cadillac i thought had the same boltpattern bc they used the turbo 400 on some of their big blocks I THINK
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 10-25-2003, 08:24 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Buick, Olds, Pontiac, and Cadillac used a seperate pattern than Chevy. Some trannys, particulary lots of 200-4r were dual drilled for either pattern.
Dinnut, sure Caddy uses TH400, but it's different bolt pattern than Chevy.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-25-2003, 09:25 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
b.o.p. motor's did have different bolt pattern's for sure... The internal part's from one trannt to the other will inter change though.. So at least you could find a b.o.p. tranny and swap the gut's with a chevy tranny to make it all work.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-25-2003, 11:41 PM   #7
onelow69
onelow69's Avatar
They make B.O.P adapter plates that go to Chevy trans. They cost around 80 dollars. I believe that Summit or Jegs carries them.
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect.
onelow69 is offline   Reply With Quote
Old 10-26-2003, 03:23 AM   #8
Tony Stewart
adaptor plate
right guys they make a plate to adapt things,but my uncle had a 69 or 70 chevy truck a few years back that had a rare tranny In It that would accept bolts of chevy and buick olds and pontiac on the (hogs head)bellhousing.they did not pmake alot of these this way just a few.
Tony Stewart is offline   Reply With Quote
