07-23-2017, 06:36 PM | #1 |
shoulder belts
I have searched through this forum and have even done a google search but can not find some shoulder belts that look factory. The only ones that seem to look factory that I have even found pictures of are the original shoulder belts. And they are almost impossible to find, and as I have heard a PITA to use.
What have you guys all found/used? Also, I need a set of white, as my factory ones are white. I thank and appreciate any help in advance
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
07-23-2017, 06:49 PM | #2 |
Moderator
Re: shoulder belts
68-70 mustang/cougar shoulder belts and retainers are a very close match. They are 2 piece and a pita to use as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
07-23-2017, 06:51 PM | #3 |
Re: shoulder belts
I have these (they stick out a bit when deployed like this but that's not how you stow them, of course). They have the metal buckles like GM, and I think that's as close as you're going to get.
I have factory shoulder belts in my '69 2+2 and use them because I wanted to keep it original, but they're an annoying pain to use. With retractable at least you can touch the radio... These are from LMC. They have several colors, unsure about white.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
07-23-2017, 07:53 PM | #4 |
BlahBlahBlah
Re: shoulder belts
The original ones are old, expensive, and just not that great...did I mention expensive?
I bought a set from Tom on this thread. Brand new, look great, and while I suppose they aren't cheap, they are a heck of a lot cheaper than the OEMs when you can find them. Plus they work great. http://67-72chevytrucks.com/vboard/s...d.php?t=657298
07-23-2017, 08:04 PM | #5 |
Old member
Re: shoulder belts
I have the late model sets in both my trucks and like them.
With my interior you can barely see them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
07-23-2017, 10:33 PM | #6 |
Re: shoulder belts
I installed these in my Burban. I got them from Buckle Up. I went through them as they were the only one with the Aqua color. Not much different to use than the ones in my S-10. The only issue I had was with the powder coating. It had to be scraped out of the bolt holes so the bolts would go through. I may have listed more in my WMB thread. Since pictures tell more than my little words can. Here's some photos. I reused the best two of the originals for the center set.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-23-2017, 11:55 PM | #7 |
How did I get this OLD!
Re: shoulder belts
Original style, just not original to my truck. Yes PITA to use but still cool.
Looking for a 67 Blue set for my other truck. Cougar belts would do. http://67-72chevytrucks.com/vboard/a...1&d=1500868349
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
07-24-2017, 12:59 AM | #8 |
Re: shoulder belts
Mine are OEM. I don't drive my truck much, so the PITA aspect doesn't bother me. I do like the cool factor of the OEMs. I found them in a '72 Blazer in the junkyard and paid $10 or $15. The extra boots and stubs in the center of the first picture were in the rear, and the belts were cut off at the base of the boots. I also found some retainers in the junkyard that go on the front of the console to hold the female belt buckles (pic 3). I'm thinking of using the hard to find spare parts to build another set based on the information in these threads by leddzepp and others.
http://67-72chevytrucks.com/vboard/s...d.php?t=455323 http://67-72chevytrucks.com/vboard/s...d.php?t=339651 Last edited by FirstOwner69; 07-24-2017 at 01:24 AM. |
07-24-2017, 11:44 AM | #9 |
Re: shoulder belts
That's what first came to mind were the ones in my 94 suburban. I bet all the original mounting holes were usable too.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
07-24-2017, 12:16 PM | #10 |
Re: shoulder belts
Mine are from Morris, they fit well and you have several choices of buckle designs.
https://www.morrisclassic.com
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
07-24-2017, 01:33 PM | #11 |
Re: shoulder belts
Not to get off subject here but where did you get that center console Z10? I have been looking for something like that.
07-24-2017, 05:36 PM | #12 | |
Re: shoulder belts
07-24-2017, 06:05 PM | #13 | |
Re: shoulder belts
07-24-2017, 08:41 PM | #14 |
Old member
Re: shoulder belts
The holes by the door I used and the drivers side center one. The passenger side center I had to redrill but I added stifner under the truck.
07-24-2017, 10:59 AM | #15 |
Re: shoulder belts
I appreciate all of the replies guys!!
CG that is the exact Idea I had in my head! Again thank you all for the help!
