Radiator Flushed
Pretty sure the radiator is original to the truck and time to get a new one. Flushed it this past weekend for a long while. There are some floaties there still. Looks WAY better now. Only had about 1 1/4 gallons in their that drained out. I should have just bought a new radiator probably?
-71 C10 long bed, 402 -91 Camaro Z28, B2L 350 -96 Tahoe 2 door 2wd -15 Tahoe LT -16 Lexus RC 350 F sport ![]() |
#2 | |
The Older Generation
Re: Radiator Flushed
Did you just flush it or did you back flush it too. Some of the bigger chunks won't come out unless you back flush it.... LockDoc
#3 | |
I figured it helped but looking at the fluid in there just looks like it picked up more crap not as much for sure but still. Spent about 3 hours total running, rinsing etc.
#4 | |
LockDoc
#5 | |
When I replaced my radiator, I drove for a few days with nothing but water and radiator flush. Then, removed radiator hoses and heater hoses (replaced them) and removed thermostat housing and block drain plugs on both sides. Flushed heater core (forwards and backwards) till water ran clear. Flushed block with garden hose in thermostat opening till water ran clear from block drains. Flushed radiator with from cap opening and inlet hose (driver side) till water ran clear. Let everything finish draining, then close up, reattach all hoses, then filled with 50/50 mix of Prestone/distilled water (+ 12oz bottle of Water Wetter).
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
#7 | |
![]() Join Date: Jul 2015
X2 on those block drains, it makes a big difference.
