Old 07-29-2017, 04:11 PM   #1
Jase lummus
Hei spark but no start
Hey guys I have a 72 gmc with hei. It will crank over has spark but will not start any suggestions
Jase lummus is offline   Reply With Quote
Old 07-29-2017, 04:15 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Hei spark but no start
Did you just replace the original points distributor with the HEI unit and then the problem started...or has the HEI been working and then stopped suddenly...
6 cyl or V8
AussieinNC is offline   Reply With Quote
Old 07-29-2017, 04:27 PM   #3
rockyrivermark
Need for info. Not much do go on there.
How did you check for spark?
Is it getting fuel?
What engine?
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 07-29-2017, 04:31 PM   #4
davepl
davepl's Avatar
Well if you've got spark then you're missing fuel or compression... gotta be one or more of the three!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-29-2017, 08:32 PM   #5
bill3rail
bill3rail's Avatar
As Mark said, Spark Fuel Compression.
Spark at the right time also helps so if the point distributor was replaced by HEI, look into that.
Fuel? Fresh fuel also helps...
Compression? All cylinders similar pressure helps too...
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-30-2017, 02:57 PM   #6
Jase lummus
It has spark, good gas, and good compression. It will sputter a little right as I start cranking then nothing. I replaced the hei distributor that was already on the truck
Old 07-30-2017, 03:13 PM   #7
harpo231
harpo231's Avatar
timing ?
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 07-30-2017, 03:18 PM   #8
Jase lummus
I can't count how many times I've timed and retimed
Old 07-30-2017, 03:36 PM   #9
truckster
truckster's Avatar
Yep... timing.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-30-2017, 03:41 PM   #10
harpo231
harpo231's Avatar
check plugs
Stan
67 swb BLU MULE
Old 07-30-2017, 04:52 PM   #11
AussieinNC
Moderator
AussieinNC's Avatar
Why did you replace the original HEI distributor? Same issue ?
This sounds like a bad ignition switch...bypass the switch or try another switch...
I have seen these ignition wiring plugs melt at the back of the switch...
I know you have checked timing...maybe time to start again from basics...
Bring cyl 1 to TDC on compression...make sure rotor is aligned with correct cap port for cyl 1...
BTW...was this truck originally a standard points style distributor? You do know if it was the power wire drops voltage down and needs to be replaced when you install HEI...
Old 07-30-2017, 04:56 PM   #12
Larry Weaver
Would the HEI be connected to original coil wire? Voltage would be low but would have spark and perhaps not start.
Larry Weaver is offline   Reply With Quote
Old 07-30-2017, 05:17 PM   #13
Jase lummus
Ive already replaced the ing wire
Old 07-30-2017, 04:44 PM   #14
franken
Gas squirting from the squirters? Get a can of spray B12 , open the throttle, shoot some down its throat, crank.
Old 07-31-2017, 08:43 AM   #15
panhead59
It sounds like you just replaced the HEI dizzy. 9- outta 10 times if a new symptom arrives immediately after doing something like that, then that part or installation is the culprit. If you had access to another dizzy, that would be a quick dbl check of the "new" Hei. It's easy to "overthink" things, I do it all the time. Start simple, at the beginning. And why was the HEI replaced? Symptoms?
panhead59 is offline   Reply With Quote
Old 07-31-2017, 09:23 AM   #16
67 chevelle
67 chevelle's Avatar
dizzy 180 degrees out ?
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 07-31-2017, 11:40 AM   #17
Mike (Asheville)
Mike (Asheville)'s Avatar
Or maybe a tooth or two off. Have you checked where the rotor's pointing at top dead center?
Mike (Asheville) is offline   Reply With Quote
Old 08-01-2017, 07:09 PM   #18
Jase lummus
Someone rebuilt the carb with mixed parts thanks guys
