Old 07-30-2017, 02:45 PM   #1
dflarsen77
Active Member
What is this bracket?
This little bracket was attached by the outer small hole you see in the pic, to one of my oil pan bolts on the driver side, in the middle of the block, covering the coolant drain plug on that side of the block. Nothing was attached to it. I've never seen it before. Anyone know? The way the big hole has a flat spot, and the notches to either side make it look pretty specific.
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline   Reply With Quote
Old 07-30-2017, 03:14 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: What is this bracket?
Only thing I can think of would be a floor shifter cable bracket but not sure why it would be on the oil pan.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 07-30-2017, 03:22 PM   #3
Killer Bee
Killer Bee's Avatar
TH350 cable bracket?
notched hole similar to this one?
Killer Bee is online now   Reply With Quote
Old 07-30-2017, 05:00 PM   #4
dflarsen77
Active Member
That could be. It has a BOP400 when I pulled it and that isn't original. It has the turbo hydra option on the SPID which I think can mean it had a 350. Still don't know why it would be on the oil pan
David Larsen
1970 Chevrolet C-10
Old 07-30-2017, 06:24 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Maybe a PO removed it but didn't want to lose it.... so he attached it to a pan bolt? People can do some crazy things....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-30-2017, 07:34 PM   #6
mikeshome
mikeshome's Avatar
My 350 motor has something like that on the pan bolt and they ram my plug wires through the big hole to keep them off the exhaust manifold,Might have been added for the same reason.
mikeshome is offline   Reply With Quote
Old 07-30-2017, 07:42 PM   #7
dflarsen77
Active Member
That makes sense why it was used, but doesn't seem like that's what it was made for. My truck had been poorly switched to headers, probably when it was rebuilt in the 80s.
David Larsen
1970 Chevrolet C-10
Old 07-30-2017, 08:04 PM   #8
jjzepplin
jjzepplin's Avatar
Idle stop solenoid off of carb?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-30-2017, 10:00 PM   #9
dflarsen77
Active Member
It is an original AC truck, although everything but one of the brackets was removed.
There's an idea. Time to look up the assembly and service manuals.
David Larsen
1970 Chevrolet C-10
