07-30-2017, 07:53 PM | #1 |
Alternator squeaking in 70 c/20
Need help finding the problem with the alternator in my 1979 c20
Probably just needs to be replaced but if you have any info let me know |
07-30-2017, 08:05 PM | #2 |
Moderator
Re: Alternator squeaking in 70 c/20
Check the belt tension first and condition of the belt...
Alternators usually don't squeak... |
07-30-2017, 08:51 PM | #3 |
As Aussie said, Belts squeak, alternator bearings may squeak right before they seize up.
With the belt removed, is the alternator tough to turn?
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
07-30-2017, 09:02 PM | #4 |
20' Daredevil (Ret)
Try changing the tension on the belt, but before you do that, put a bar of soap against the belt while the engine is running. It will often silence (or at least change the sound of) a squeaking belt. Be careful not to damage any body parts, such as your fingers.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
07-31-2017, 02:20 PM | #5 |
take it to Auto Zone & have them test it
Tags |
#chevy #alternator #c20 |
