Old 08-01-2017, 06:33 PM   #1
thejangler2013
Angry c20 front drum backing plate help, compatibility?
So I cracked the front drum brake backing plate on my 69' c20 2wd where the brake bleeder nipple goes in (drivers side). Since it is 3/4 ton I am having the hardest time trying to find a replacement for it. Any thoughts as to what other years could work in terms of a replacement so I can broaden my search? no luck online for the backing plate for that year
thejangler2013 is offline   Reply With Quote
Old 08-01-2017, 06:47 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: c20 front drum backing plate help, compatibility?
Become a subscribing member and post a WTB(want to buy) ad in the classified section I'm sure you'll be offered a few today .
Old 08-01-2017, 06:56 PM   #3
harpo231
harpo231's Avatar
Doesn't the bleeder go in the wheel cylinder ?
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 08-01-2017, 07:26 PM   #4
Larry Weaver
Could youre backing plate be welded and ground??
Larry Weaver is offline   Reply With Quote
Old 08-01-2017, 07:43 PM   #5
thejangler2013
Smile Re: c20 front drum backing plate help, compatibility?
duh! i think it does, guess i was just freaking out for no reason. thanks much for the reminder, this makes life so much easier!!
Old 08-01-2017, 11:51 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I agree with Larry. Weld it up (or have it welded) and grind it down smooth.....
LockDoc
Leon
backing plate, c20, drum brake
