Old 08-03-2017, 08:10 PM   #1
In The Ten Ring
Front fender side emblem questions.
1). Where does one find those nuts that hold the emblems on?
2). What are those nuts called?
3). Was there any cushion material between the emblems and the fender?
Thanks!
In The Ten Ring is offline   Reply With Quote
Old 08-03-2017, 08:24 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Front fender side emblem questions.
1) Find at most Corvette and other types of restoration parts places... also lots of hardware stores. For example:
http://www.parts123.com/corvettecent...050f&ukey=5625
https://www.mcmaster.com/#spring-speed-nuts/=18sb3ap
2) Commonly called emblem nuts, flanged push nuts, pal nuts, speed nuts, etc.
3) No cushion material used.
FirstOwner69 is offline   Reply With Quote
Old 08-03-2017, 08:26 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
LMC has them under 30-0812...
Emblem nuts, speed nuts...
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=114
No padding under emblem...
AussieinNC is offline   Reply With Quote
Old 08-03-2017, 09:40 PM   #4
In The Ten Ring
Thanks guys!
One last question....fenders have to be off the truck to put the emblems on?
Old 08-04-2017, 06:11 AM   #5
randy.powell
Assembling mine now. If you have the fenders off, do it then - if not, pull the inner fenders (wheel wells). If you have the outer fenders on, shimmed - gaps set, etc. you don't want to mess with those!
Randy
randy.powell is offline   Reply With Quote
Old 08-04-2017, 03:32 PM   #6
OregonNed
OregonNed's Avatar
Inners pulled for sure - makes all the difference in the world..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 08-04-2017, 04:41 PM   #7
In The Ten Ring
Inner fenders are off.
I don't think I can put the "Custom 10" emblems on without removing the fenders. Ugh.....and they went on so easily!
Old 08-04-2017, 09:25 PM   #8
mike16
i too would recommend a corvette vendor to locate correct nuts
how ever
I just purchased a set of custom C-10 front fender emblems for my 72 from Classic Parts, and those nuts came with the chrome. Very nice chrome bits too
mike16 is offline   Reply With Quote
Old 08-04-2017, 09:44 PM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have found speed nuts on my old Chevy Trucks that the PO packed the cavity with caulk for a better hold. Have not copied it yet.
Old 08-04-2017, 10:41 PM   #10
In The Ten Ring
My truck's PO (my dad) broke his emblem studs off or the painter did. Dad just glued the emblems back onto the sides......I can remember him doing that.
Getting these "emblem nuts" is one of the last things for me to do now......I am going to try and "inject" blue nail polish into the "Custom/10" emblem, picked it out to match the front grill emblem color.
Need to get this done so I can get the truck back together!
Old 08-04-2017, 11:23 PM   #11
Grumpy old man
Grumpy old man's Avatar
Use barrel clips so you don't have to remove the fenders , You get the size that fits the emblem studs . the clips are installed into the hole in the fender from the outside and then the emblem studs are pushed into the clips ,It's easy , they are cheap and it works .
https://www.summitracing.com/parts/s...SABEgKlVPD_BwE
they are on ebay with an assorted pack cheap, napa, most auto part stores
Old 08-05-2017, 02:40 AM   #12
In The Ten Ring
Do you use those on your builds Grumpy?
How do they come back off? Twist off?
Old 08-05-2017, 08:25 AM   #13
Grumpy old man
They were used for installing chrome trim on cars with vinyl tops in areas were there was no rear access on the rear quarters , with a little effort they will pop back off , More than once you'll hear of someone forgetting to install the emblems before installing the fender and loosing access , they also work when you want to install another emblem after the car/truck is done just by drilling the correct holes popping in the barrel clips and pushing on the emblems .
Old 08-05-2017, 08:03 AM   #14
70 shorty
Where's my beer?
70 shorty's Avatar
You might try your local Lowes. Mine has a surprising assortment of automotive fasteners.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 08-05-2017, 08:08 AM   #15
Katrina/10
Katrina/10's Avatar
I was able to install my emblems without removing the fenders by taking out the bottom bolt and wedging a block of wood between the fender and cab at the bottom. It's a stretch to get the top nuts on, but it can be done.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
