HEI vs. MSD
I contemplating switching from HEI to an MSD ignition system. My question is would the MSD be a more reliable system?
![]() Join Date: Jan 2001
Re: HEI vs. MSD
Have you been having problems with the HEI? GM's factory HEI is an extremely reliable system, so I'm not sure you'll find anything more reliable than a properly operating HEI.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Re: HEI vs. MSD
just recently. Ignition module went out. Now it was spitting and sputtering like bad fuel. It has new E3 spark plugs which are about 2-3 months old. Gonna change back to ACDelcos and see if improvement.
![]() Join Date: Feb 2013
Re: HEI vs. MSD
Double check your grounds. Make sure all are present and in good shape. Every time I have had or seen a module go out it is because of bad or missing grounds... HEI does not tolerate voltage drops.
Re: HEI vs. MSD
I for one am not a big fan of e3 spark plugs. They are overpriced plugs and I've heard of a bunch of problems with them. And 2x checking the grounds.
Re: HEI vs. MSD
Just drove home from work. As long as the rpms stayed below 2500 it ran fine.
Re: HEI vs. MSD
Use a 12 Gage wire for your HEI. I have mine fused
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
Re: HEI vs. MSD
All grounds are good. This started after module went out. Truck has been rewired with a painless wiring direct replacemnet kit. Replaced E3 plugs with R45ts, which are recommended bt GM for this motor. I replaced cap and rotor while i had it apart with an MSD brand HEI kit. Today was alittle better but still acted funny
Old member
As far as reliability the HEI is one of the best systems out there for no more money than it takes to install. You want find a better dizzy for the money.
As far as the problems you are having: #1 what gap is on the plugs HEI say no more than 35-40 no more. Plug gap Don't be tempted to excessively widen the gap. The correct gap is 0.035"- 0.040" for the majority of cases. Using plug gaps wider than that is unnecessary when using a basically stock HEI ignition. #2 Did you put the paste under the module? Use a heat sink paste (available from Radio Shack and computer shops) on the bottom of the module and be sure the surface of the distributor body where it mounts is clean. The heat sink compound (not dielectric grease) helps transfer the module heat into the distributor body which acts as the heat sink. Failure to do this can lead to an early failure of the module. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: May 2013
Re: HEI vs. MSD
If volts drop below 12 the msd has a tendency to not work , heis are better at this , therefore in my opinion , better for street use .
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
Re: HEI vs. MSD
Andy, i cleaned the mounting surface on the dizzy. I applied the grease that came with the module. I went with .045 gap as recommended by GM. I havent experienced any voltage drops that ive notice. Alternator is putting out 14+ volts according to my gauges.
Could the capacitor been damaged. |
Re: HEI vs. MSD
A properly wired, USA-made HEI (ie: not a Chinese knockoff, unless it's a well respected knockoff) should last next to forever.
It's when they're wired to the resistance wire, or to the wiper motor, or nonsense like that which can give them a bad name. Properly set up, the GM ones are bulletproof. I wouldn't add an MSD, as it's just an extra point of failure. If you have a supercharger, you might need the additional spark energy to jump the gap, but for most motors, there's no benefit.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Re: HEI vs. MSD
The dizzy is a Speedway motors brand. Allegedly blueprinted. I think it is made off shore though. Tried to get some specs for and they couldnt gjve them to me.
Re: HEI vs. MSD
#15 |
Re: HEI vs. MSD
>>This started after module went out. <<
>>As long as the rpms stayed below 2500 it ran fine.<< First place to look is the wires from the pickup coil -to- the HEI module. The vacuum advance is constantly tugging on those wires as you were when you replaced the module.
'67 GMC 2500, 292, 4spd, AC |
#16 |
Re: HEI vs. MSD
Not running the vacuum advance
#17 |
Re: HEI vs. MSD
Sounds dumb, but check the all wires plugged into the dist. cap. and make sure the module is connected properly. Ran into that a few times, learned the hard way. As far as HEI or MSD, unless you have a performance engine that needs the extra spark, I'd stay with the HEI. You can do some performance upgrades to the HEI to get more spark out of one. MSD makes a better module, coil, cap, and rotor for a HEI, makes a little bit a difference but not much.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
#18 |
Re: HEI vs. MSD
Ok. Good point, one of the connectors to the module I thought I might have flipped it.
#19 |
Old member
Another minor but very important part is the screws used for the coil and cap. If they are to long they go all the way through and create a path way out so the truck runs rough. Just thinking out loud.
#20 |
Re: HEI vs. MSD
At least most GM HEI assemblies don't have enough mechanical advance on their own without using the vacuum hooked to a ported source. Also check and make sure that your mechanical advance is not stuck.
What is your total advance and what is the rate it comes in? You may just need more total advance. That too fits with some of the problems you seem to be having. As far as reliability, I'd say 6 of one half dozen the other. But in terms of cost and ease of replacement parts, HEI for the win. FWIW, I run both. I have an MSD ready to run small cap in my Jimmy, an 8560 with a 6T in the Camaro, a couple of of the Street MSD HEI and a tach drive 6AL setup on my 'vette. They all work great. But the HEI a fraction of the cost. My '69 short step running a Chinese knockoff HEI for $59 going on several years and several thousand miles.
#21 | ||
"I ain't nobody, dork."
Re: HEI vs. MSD
What year truck is this in? Did you convert a 67-72 rig with an HEI? Did you use the old stock points style coil wire? If you did, it's a resistor wire and will cause problems with the HEI. Did you gap your plugs to .045 for use with an HEI?
Gary
#22 |
Re: HEI vs. MSD
Yes i converted my 71 c10 custom deluxe to HEI. i have 8mm Accel wires and Delco plugs gapped to .045.
Strang thing, while driving home thus afternoon the truck ran normal, no missing even under load |
#23 | ||
Re: HEI vs. MSD
Where did you wire in the power wire for the HEI?
Gary
#24 |
Re: HEI vs. MSD
I re-wired the whole truck with a painless kit. The power for the HEI was in the harness
#25 | ||
Re: HEI vs. MSD
Sweet. I read you did a Painless kit but wasn't sure how the wire came to the HEI.
![]() Gary
