![]() Join Date: Nov 2007
1988 K5 blazer lower tailgate repair panel
Does anyone produce a lower patch panel for a K5 blazer tailgate?
Thank you, Tim |
Re: 1988 K5 blazer lower tailgate repair panel
Don't think so. I had the same problem while restoring my '74. Wound up with 3 wreaking yard tailgates and patched the best one with parts and patch panels cut from the others.
Hard finding a nice one that isn't cracked or rusted out.....
1972 Highlander PAC B 400BB-SOLD 1974 K5 Blazer-6.0 swap 1974 C20 Long Bed 454 1977 GMC HeavyHalf several adopted orphans |
Yea, just start combing craigslist for a used, clean one. Best way to do it. You could buy one from LMC but I would assume that's pretty expensive and not OEM.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
Every used tailgate I find has the same rust problem. Still looking,
Thanks, Tim |
Found a good solid tailgate, dented in the top. Able to get the repair panel needed.
Thanks, Tim |
