454 w/ th400
Hi all, guy in town has a 74 k30 he's parting out, he's selling the 454 w/th400 in it and wants 1k for both, its still in the truck so i can drive it, i wanted to drop it in my 72 c20, millage unknown do you think it a fair deal or should I pass? Thanks
Re: 454 w/ th400
If that TH400 is actually in a 4wd truck it might have too short of a tailshaft to work in your 2wd truck. Might want to check that out before you drop that cash.
1k sounds reasonable as long as the mileage isn't too high and everything works as it should.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
Re: 454 w/ th400
Correction..motor and tranny coming out of a C30 and while I'm here, what other parts would I be needing from the c30, ie: cross member, drive shaft motor mount brackets? Thanks again
![]() Join Date: Aug 2004
Re: 454 w/ th400
I'd grab the engine mount frame stands and mounts for sure, you will need those.
Not sure about the cross member and drive shaft.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Re: 454 w/ th400
Be sure to get the slip yoke , steering colum and frame linkages and the kick down switch and wiring for the t400.
The 4 core rad and the mounts if available. Upper and lower rad hoses if salavagable. and dont forget that rad should have the trans cooler lines. The frame stands for the motor mounts. Exhaust manifolds, and any of the down pipeing way easier than headers Just a few i thought of.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
