ID OE Blazer Doors?
Is this correct to a 69 to 71 door? I was stunned at how crude they produced these. Is there some sort of cover that goes on top of the vent frame and edge door sill?
Thanks, Steve |
Re: ID OE Blazer Doors?
Pic 2
Hard to tell from those pics if they're correct for those years.Need to see inside of the door to see if there is a plastic or a metal ferrule and screw...but those doors are crude from the factory. There is a weatherstrip type channel that slides down into the door that will cover the one cut then there is another plastic piece to cap by the top of the vent window.
![]() Join Date: May 2011
Doesn't look like it has the reinforcement for the latch which should be spotwelded in may be a truck door cut down.
![]() Join Date: Sep 2011
^^^^^^^^ Same thing I saw.........cut truck doors
And yes, there should be a cap that covers the top.
1967 C10 SWB Owner - Rustbelt Restorations |
Factory Blazer doors were cut truck doors too. At least that's what my Jimmy looked like when I re-did the doors 25 years ago. With some latch reinforcement added. The cap on the back of the door is molded into the rear window guide rubber.
