Cowl Mounted Hood Hinges: 60-66 and 67-72
We are offering Switch Suspension cowl mounted hood hinges for your C10! Switch Suspensions Cowl Mounted Heavy Duty Hood Hinges Will Support Your 60-66 C-10 Hood With 3/8" Thick Hinge Arms Pivoting On MDS Filled Nylon Bushings & High Stregth Shoulder Bolts For Accurate & Smooth Operation. Weld On Hood Mounting Plates Come With Pre Welded Nuts For Hassle Free Hood Installation. Precision CNC Cut & Tig Welded HRPO Steel. Made In The USA.
Gas assisted for easy operation and no hood prop needed! All products are black zinc coated. Includes: - Cowl Mounted Hood Hinge Kit (pair) - Gas Struts - Weld On Hood Mounting Brackets (pair) - Mounting Hardware $400 For the Set ![]() ![]() ![]() |
Re: Cowl Mounted Hood Hinges: 60-66 and 67-72
Any reviews on quality compared to pb fab?
