18x8 20x10 Torq ii's
Hey Guys
I just bought this truck want to put some 20x10 Torq 2's on the back anybody running a 18x8 and 20x10 combo looking for pics and opinions if it will look out of place looking for a slight rack |
Diggin The SquareLife
Re: 18x8 20x10 Torq ii's
you can still get the rack look with drop parts.......18's front don't look right with 20s in the rear even if its lowered......I would run a 20" in front also
18x8 & 20x10.....
Scoti,
I have the same rear wheels (TTII) and sits the same as yours in the back. However the front end on mine is not low enough because of the wheels / tires I am currently running. What back spacing are your front wheels and what tire are you running? What is your drop combo on the front. Obviously spindles but did you replace or cut the springs. Any rub issues? Thanks |
#5 | |
Drop was 3" spindles & 1-coil cut from the original sbc springs. I trimmed the factory bump-stops down a little but they kept the tires from buzzing. Without the bump-stops, it buzzed too much.
Thank you - my 17 X 8 TTII with 4" BS are my problem. Will have to consider another pair of wheels. Perhaps tires too as it is tough to find matching tires for a set of 17's and 20's.
I do believe my thread has been hijacked..........................carry on with your issues
My 87 on black chrome TT's, 18's and 20's. I went with a 8" on the rear and used a spacer to bring it out flush.
Not hi-jacked. You asked for pics, I provided per your request. Questions will arise from others based on the content within the replys. You might have wondered the same related questions.
18x8 (255/55/18) front
20x10 (285/50/20) rear |
Another
looks good thanks
I would use 20's at all four corners. I think it would look better.
Here is my truck with 18's up front and 20's in the rear. |
Definitely.
