New wheels
Hey guys I found a set of wheels that doesn't match my wheel pattern I know that I can buy adapters to "compensate" for that but they have a +22 offset how thick do the adapters have to be. By the way it's a 72 gmc 2wd
#2 | |
The Older Generation
Re: New wheels
I'm not a very knowledgeable wheel guy but not sure what you mean by +22 offset.... LockDoc
![]() Join Date: Jul 2015
Re: New wheels
That would be -22 millimeters.
Re: New wheels
In that case now I'm really lost.... ![]() LockDoc
Re: New wheels
We're going to need more info to help out. How wide are the wheels? The offset is meaningless without knowing the width. Once we know the offset and width, we can convert to the backspacing which is what most of us are used to dealing with.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
![]() Join Date: Nov 2013
Re: New wheels
IIRC the "offset" is the distance from the centerline of the wheel to the mounting surface....and the "backspacing" is the distance from the back side of the wheel to the mounting surface...now as to whether the wheels mentioned will fit...can't help there
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#7 | |
Re: New wheels
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
![]() Join Date: Feb 2001
Re: New wheels
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
motor exploder
Re: New wheels
OP - you need to know how wide the wheels are, then you need to buy a tape measure and find a straight edge.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Re: New wheels
I believe there 22 mm = .866= 7/8 . 7/8 off the center of rim. It said +22 but not sure which side of the middle there talking. Front or back
Re: New wheels
BS= Back Spacing...(it took me a few minutes to get it...hahaha)
